JCB Posted October 11, 2006 Share Posted October 11, 2006 What should I expect? I seem to be getting less than 30mpg Thanks Quote Link to comment Share on other sites More sharing options...
white90 Posted October 11, 2006 Share Posted October 11, 2006 we got 34 around town and 39+ on a run using cruise control then again the tank was completely empty in less than 300miles on the run to trade it in. Quote Link to comment Share on other sites More sharing options...
MudAllOverIt Posted October 17, 2006 Share Posted October 17, 2006 I seem to be getting less than 30mpg There was a spate of this sort of problem with a batch of early 2004 MY TD4 Freelanders -- from memory it was caused by problems with the mass airflow sensor but I'm not 100% sure about this as there also other performance problems (which might be the MAF issue I'm thinking of) and injector wiring loom issues around the same time. I'm fairly certain there's a technical bulletin on the TD4 fuel consumption issue... Quote Link to comment Share on other sites More sharing options...
