dm7288 Posted December 28, 2013 Share Posted December 28, 2013 Hi all, I have fitted a fairey overdrive to my series 3. I replaced all of the overdrive gaskets to prevent leaks. Bloody thing still leaks, but out of the hole in the top cover that has a split pin in it. The cover has a plate on the underside to deflect the oil away from the split pin and hole, I assume the split pin acts as a breather. Anyone know of a fix to prevent this? Dont want to put a self tapper in the hole as it might cause a build up of pressure? Any ideas? Dave.. Quote Link to comment Share on other sites More sharing options...
Tanuki Posted December 28, 2013 Share Posted December 28, 2013 Are you using the correct oil? Some oils 'foam' excessively and then as the air inside is heated it expands and blows oil-bubbles out. Also did you fill it to the correct level? I remember back in the days of GKN/Laycock O/D gearboxes on things like Transits, Humbers, TVRs, Triumph-2000s etc there was a bent-wire thing you used to poke into the filler-hole to test the oil level - which depending on design could be an inch or so _below_ the filler-hole. If you just filled-it-until-it-overflowed then you would often end up with bad things [oil working its way up the speedo-cable and ruining the speedo itself was a favourite on Transits]. Check with the Fairey manual to see what the fill-level should be! If that doesn't fix it, you could always remove the split-pin, drill/tap the hole and fit a threaded 'tail' adapter then run some plastic aquarium-pipe to a catch-tank somewhere? Quote Link to comment Share on other sites More sharing options...
Serious Series Posted December 29, 2013 Share Posted December 29, 2013 Oil filler plug should have a dip stick fitted to it level is correct when it is on the mark after being screwed into O/D Some have removed plate and fitted pnuematic fitting to allow remote breather to be fitted ie higher. Quote Link to comment Share on other sites More sharing options...
dm7288 Posted December 29, 2013 Author Share Posted December 29, 2013 I have used the correct oil, set the level with the dipstick that is attached to the filler plug. I will fit a pipe fitting and a length of pipe to get the breather higher up. Cheers guys.. Quote Link to comment Share on other sites More sharing options...
David Sparkes Posted December 29, 2013 Share Posted December 29, 2013 An extended breather is a common way of stopping the OD throwing out oil mist, although checking the level is correct is always a good 'first move'. The OD runs quite hot, so allowing it to 'breathe' is essential; the trick is to do it without allowing the oil to leak. That said, some people think the aroma of hot EP90 is an essential part of Series motoring :-) If you aren't familiar with pneumatic fittings and pipes you can always buy kits off ebay. This one relates to axle breathers, where adapters screw into the axle, replacing the existing ball valves that are prone to sticking. The 'extension' of the pipe means that no valve is required to combat water ingress. For the OD and gearbox / transfer box the idea is that the existing breather hole is drilled out and tapped to take the same threaded adapters. These breathers are normally teed together near the transmission, then one common extended pipe is lead away. If you want a complete vehicle kit, or any other variation, then I suggest you contact the vendor directly via landy@rms1.co.uk, when any prices will reflect the fact that the sale will be direct. I know the vendor through the Series 2 Club Forum, but have no business connection with him. HTH Quote Link to comment Share on other sites More sharing options...
dm7288 Posted December 29, 2013 Author Share Posted December 29, 2013 I have several 90 deg push fit pipe adaptors that will do the job nicely so I'll sort it out tomorrow.. Quote Link to comment Share on other sites More sharing options...
Pollywog Posted December 30, 2013 Share Posted December 30, 2013 I can't get the filler out of mine so just poured in a measuered amount through the top plate I too have drilled out the plate and fitted a push-fit elbow for a raised breather, along with the same on the transfer case and gearbox, I ran the pipes upto a manifold on the bulkhead rather than tee them too closely together. I tried tapping the plate on the overdrive but it didn't give much of a thread to screw in to so I have also threadlocked a back nut on. When I find someone that can do it I'll get the nut brazed onto the plate. Quote Link to comment Share on other sites More sharing options...
dm7288 Posted December 30, 2013 Author Share Posted December 30, 2013 Breather pipe mod done today. Will at a later date do the axles, transfer and gearbox and link them all up. Quote Link to comment Share on other sites More sharing options...
