Part number help for D-90 warning panel bit
Hey folks. US D90 owner. I've lurked for some time but finally need some help tracking down a part number or vendor. This electrical bit is from the harness of the warning lamp module on the older Defender's. Does anyone know the PN or how I might source more of these to modify my warning light dsiplay?
Thanks in advance!
Thanks guys, yup, this is from the back of the wiring loom for the lights on the warning lamps below the gauges.
Western, I'll check Autoparts, thank you for the link. I'd hate to ask you to post that to me from overseas!
OK, let us know if you get some or want the bits I've got, no probs with posting as they'll eventually get thrown in the bin.
Guest diesel_jim
On euro (not sure if the American ones are different) the warning light unit has lots of separate bulb holders that clip into place, and the cables are attached by crimp connectors.
You will be welcome to mine - I've replaced the factory tan coloured plug that clips onto the warning lights with aftermarket multiplugs, in order that I can see the warning lights during daylight hours!
The tan coloured plug (if the terminal that you are after is within that plug) can be posted if you need it - it's scrap otherwise
Guest diesel_jim
Ahhhh yeah, i recognise it now! the main multi-plug that supplies the warning panel!
"Clink", goes the penny, as it drops! :rolleyes:
Thanks folks. I am striking out with Maplins and autosparks. I PM'ed a few of you to see if I can't get a hold of the "junk" ones you have. Let me know.
Very frustrating not being able to track this down.
Got both PM's from you & a reply has been sent.
