rudd86 Posted March 3, 2014 Share Posted March 3, 2014 finally almost finished fitting h14 winch yesterday and the bolts that held the pto cover on the rear of my transfer case don't seem to be long enough to bolt up the drop box properly, it feels like there only in a few threads and would rip the thread out if I tried to tighten anymore. the drop box gear engages freely and is fitted up tight with the correct gasket, so any ideas on the bolt size I need to go get today? thanks Quote Link to comment Share on other sites More sharing options...
rudd86 Posted March 3, 2014 Author Share Posted March 3, 2014 m14x25 jumps out of parts list.. hmm Quote Link to comment Share on other sites More sharing options...
Daan Posted March 3, 2014 Share Posted March 3, 2014 I used studs and nuts in this application, to get more engagement. longer bolts than standard would also give you more engagement, but you cant get them in. I am sure you have seen why you can't get them in! Daan Quote Link to comment Share on other sites More sharing options...
miketomcat Posted March 3, 2014 Share Posted March 3, 2014 The bolts used on the Ali covers are long enough it's the ones used on steel covers that are to short. They are m10 from memory but maybe m12 and you can just get them in but a couple are easier if you put them in place before the box goes up. But studs does sound easier still. Mike Quote Link to comment Share on other sites More sharing options...
rudd86 Posted August 25, 2014 Author Share Posted August 25, 2014 still stuck with this. I got bolts and managed to get them to fit. cant remember what size. months later the gasket has decided to leak oil badly. local landy garage wants £100 to fit a replacement. I just cant face doing it again. its a pig of a job top do without a pit or ramp. I think stud and nut conversion would be the way forward. can anyone shed any light on the size thread and length needed? also is it worth doubling up gaskets/making my own thin rubber one/using sealent instead/instant gasket? thanks Quote Link to comment Share on other sites More sharing options...
