bushwhacker Posted March 24, 2014 Share Posted March 24, 2014 Hello out there. Are there just 3 frost/core plugs behind the turbo, exhaust manifold on the 300tdi and are they all the same diameter? The middle one on my engine has developed a pin hole leak. I'm thinking the manifolds will need to come off to replace the plugs. Quote Link to comment Share on other sites More sharing options...
Nigelw Posted March 24, 2014 Share Posted March 24, 2014 Another question on this subject, is a 300 the same as a 200 as in they have another hidden core plug behind the timing chest? Most likely you'd be better to pull the manifolds, you know if you don't do it first that you'll end up anyway, that's how it normally works for me Quote Link to comment Share on other sites More sharing options...
bushwhacker Posted March 24, 2014 Author Share Posted March 24, 2014 I agree on the should have done that first scenario. I like your quote "Follow the adventure" I thought of another "Own a Landrover and be in the adventure" Quote Link to comment Share on other sites More sharing options...
PaulN Posted March 25, 2014 Share Posted March 25, 2014 Hello out there. Are there just 3 frost/core plugs behind the turbo, exhaust manifold on the 300tdi and are they all the same diameter? The middle one on my engine has developed a pin hole leak. I'm thinking the manifolds will need to come off to replace the plugs. Yes all 3 the same behind manifold - all in a line - approx 53mm Dia. as measured in rubbish light. There's also one on the block, rear of engine by flywheel of that size, one just above that one head at approx 34mm and one on engine block front just above timing case/cover behind water pump and steering pump bracket. Someone else might know exact sizes and of others.... HTH. Quote Link to comment Share on other sites More sharing options...
bushwhacker Posted March 25, 2014 Author Share Posted March 25, 2014 Thanks for info. Wouldn't you know I had the engine out to do the clutch fork a few week ago and it just never occurred to me to check the frost/core plugs. Next time the engine comes out I hope I am not the owner. ;-) ;-) Quote Link to comment Share on other sites More sharing options...
Boydie Posted March 26, 2014 Share Posted March 26, 2014 Welsh plugs are easy to replace, the three you mention will require removal of the intake and exhaust manifolds however. Remove the manifolds and with a sharp pointed chisle punch the centre of the welsh plug, it will "shrink" and be easy to remove, ensure the hole is clean and dry, smear some Locktite No. 3 or Rolls Royce liquid gasket compond on the new plug and tap the dished centre flat, it will expand and seal, it's as easy as that. The rear one (if its leaking) will require removal of the engine, the front one, if its not leaking currently, I'd advise you replace the next time you have to replace the infamous "P" gasket a or fit a new water pump.. Quote Link to comment Share on other sites More sharing options...
bushwhacker Posted March 26, 2014 Author Share Posted March 26, 2014 Just got the 3 under the manifolds changed. Boydie's tip to use a chisel and punch the center would be a good way to remove the plugs. I wasn't sure as to whether I should put any thing on the new plugs so i went for a very light smear of copper grease I hope it wasn't the wrong thing to do. I have noticed a slight weep on the left one, haven't run the engine up to temp yet so I hope it expands to a tighter fit. Fingers crossed and thanks guys. Quote Link to comment Share on other sites More sharing options...
Boydie Posted April 1, 2014 Share Posted April 1, 2014 Hummmmm I said to use Rolls Royce jointing compound (AKA Locktite No.3) but if it continues to weep a tap or more in the centre -- and JUST a tap --- will cause it to expand a bit more and seal, if not, replace it and clean the bore it sits in and use a sealing compound, not copper grease.. Quote Link to comment Share on other sites More sharing options...
difflock88 Posted April 12, 2014 Share Posted April 12, 2014 Hi All, I'm just replacing the frost/core plugs on my TD5 Disco, one was leaking behind the engine mount under the inlet manifold, is there another 3 plugs under the exhaust manifold as well? Quote Link to comment Share on other sites More sharing options...
Boydie Posted April 14, 2014 Share Posted April 14, 2014 Sorry, I'm unable to help you there as I've never had a good look at a TD5 engine. Quote Link to comment Share on other sites More sharing options...
difflock88 Posted April 17, 2014 Share Posted April 17, 2014 No worries, info from LR is that there is only the 3 core plugs under the inlet manifold. The job went pretty well, removed the fuel cooler, inlet manifold & engine mount, replaced the 3 core plugs, it was a bit awkward but we got there, also replaced the 2x O-rings in the fuel cooler while it was out. Filled with water and pressure tested it, all ok. Quote Link to comment Share on other sites More sharing options...
