Front Brake Disc To Hub Bolt
Hello,
I have an early 90 (1986) with original front axle.
Unfortunately one of the bolts holding the brake disc to the hub on the front axle sheered.
Looking at the parts catalogue I should replace it with bolt AFU1180 and spring washer WL110001L. However, LRDirect cannot supply this bolt and it is not recognised by Paddock.
Suppliers on ebay would seem to indicate that AFU1180 (up to VIN 930455) is the same bolt FTC1368 (from VIN 930456).
Can I use FTC1368 and if so do I use the spring washer or just use threadlock?
Thanks
Mark
both are Metric thread, the AFU bolt is no longer available or supplied, only the ftc1368 bolt,
I can't remember if both bolts are the same length from under the head to the end of thread, if the newer version is longer then fit with the spring washer if same length it's your choice of spring washer or thread lock compound
