trying to identify my rv8 heads.....
So, I have n rv8 from a high compression rrc, what I can't decide is what the heads are, they have a big bolt next to the exhaust ports, on most pictures of heads, this bolt is just a blank casting...... the question is, what was originally in where the bolts are???
Sorry, you've misunderstood, the bolts I refer to aren't head bolts, they're next to the exhaust manifold ports, as if they had at some point had some sort of o2 sensor or something in them, but on every cylinder!???
