Simon119 Posted July 3, 2014 Share Posted July 3, 2014 Morning All Does anyone know the manufacturer and part number for both the male and female OBD II connectors, as found on a TD5 90?? I need to make an extension cable for mine and the pre-made ones you can buy won't work as I need it to pass through a grommet. Any help would be much appreciated Cheers Simon Quote Link to comment Share on other sites More sharing options...
PaulMc Posted July 3, 2014 Share Posted July 3, 2014 I can't help you with a part number for an OBD II male plug - but, one of the ready-made extension leads would do for this part and the cable. The OBD II female socket used on TD5 Defenders is TE (AMP) part number 348822-2 - which is not easily available in the UK, and would have to be ordered from a US supplier. However, it is available from Land Rover, as part number YPC107920 http://www.brit-car.co.uk/product.php/199149/5497/connector___cable The female terminals are Land Rover part number YPL10108 - but, these are not available to order. However, they can be bought under their TE (AMP) part number 776001-1 from RS, as RS part number 712-2056 http://uk.rs-online.com/web/p/pcb-connector-contacts/7122056/ . Quote Link to comment Share on other sites More sharing options...
Simon_CSK Posted July 4, 2014 Share Posted July 4, 2014 I would have thought you could get the female plug from any salvaged Disco 2 or P38 and above. Quote Link to comment Share on other sites More sharing options...
Simon119 Posted July 4, 2014 Author Share Posted July 4, 2014 Thank you very much gents. Much appreciated. Quote Link to comment Share on other sites More sharing options...
