TD5 Fuel Pipes
  • 2 weeks later...
I'd be inclined to buy a genuine Land Rover fuel pipe assembly so that then it will be a straight swap which will be the simplest option for you.
I would imagine that Rovers North or one of the other North American specialists would be able to get you one saving you from having to order from abroad.
HTH
Mo
No it would be quite straightforward. A like for like replacement will allow you to remove the old pipe from the clips on top of the chassis rail noting each location as you go and then clipping in the new pipe.
It shouldn't be a difficult job even for a novice.
Do a search on the forum for the priming procedure for the TD5 which will be necessary having replaced the pipe.
Mo
