James NZ Posted August 13, 2014 Share Posted August 13, 2014 Hi guys, I have the TD5 head in the engine reconditioners at the moment and no cracks. Yay! However there is a wee bit of distortion and I want the head skimmed the least amount just to get it flat again. There then followed a discussion on valve stand down and the boys (engineers) said no worries we'll just cut the seats. According to LR the seats can't be cut. Does any one know why that is? I have found some part numbers, ERR7049 & 7050 for new seats so presumbly these could be fitted if required? I am aware that the valves can be lapped, but this may not be enough to obtain the correct the stand down. Some background info. They only crack tested it late this avo and asked me to pop in on the way home, they haven't yet tested it to see how flat, or not, it is. So I'm slightly ahead off myself but would like some opinions before they start machining it. Thanks for any insights. Cheers, James NZ Quote Link to comment Share on other sites More sharing options...
Rangy35 Posted August 13, 2014 Share Posted August 13, 2014 The workshop manual also states not to resurface the head. There is no problem in doing a complete head rebuild, its safe within the standard rules of rebuilding. Quote Link to comment Share on other sites More sharing options...
James NZ Posted August 13, 2014 Author Share Posted August 13, 2014 Hi Rangy The manual is quite scary to read actually, it doesn't take much to be wrong before you need to replace alot of parts according to LR parameters. Cheers Quote Link to comment Share on other sites More sharing options...
Shackleton Posted August 17, 2014 Share Posted August 17, 2014 James, I had worries about this question too last month when doing my head gasket. The head will wear having up to 8 thou, some say 10, skimmed off it. My engineer, who is renowned for his expertise, told me that the surface was very bad, and took approx 6 thou off it. He assured me that valve stand down wasn't going to be a problem and that no modifications needed to be made in relation to the valves. Everything has been perfect in the last fortnight of having the D2 back on the road. Quote Link to comment Share on other sites More sharing options...
