Theoof Posted September 13, 2014 Share Posted September 13, 2014 Hello everyone , I'm wondering could anyone tell me if drive flanges from an early defender should fit a Later one I've got flanges with the part number FTC5806 will these fit my 1997 defender Quote Link to comment Share on other sites More sharing options...
western Posted September 13, 2014 Share Posted September 13, 2014 part number should be FRC5806 [NOT FTC5806] these are for 90/110 with rear drum brakes Quote Link to comment Share on other sites More sharing options...
Theoof Posted September 13, 2014 Author Share Posted September 13, 2014 part number should be FRC5806 [NOT FTC5806] these are for 90/110 with rear drum brakes Thanks Quote Link to comment Share on other sites More sharing options...
AndrewHorsfield Posted September 14, 2014 Share Posted September 14, 2014 Hi, the early ones & newer ones are different. Different holes and the older ones are thicker. Have a look at the KAM website, they have ones with 10 holes, so that either set of 5 holes fit, plus a spacer to make them wide enough for the older hubs. Not suggesting you pay their prices, but it made it pretty clear for me to understand the differences Quote Link to comment Share on other sites More sharing options...
Snagger Posted September 14, 2014 Share Posted September 14, 2014 The older type are not only thicker, their nose protrudes more and they have a bigger internal void to clear a greater stub axle protrusion. My guess is that they will fit the hubs, but might have spline differences with the shafts (diameter may be off) and would certainly pull the shafts out too far so the diff end doesn't locate properly in the diff's side gears. Quote Link to comment Share on other sites More sharing options...
