muddy Posted October 19, 2014 Share Posted October 19, 2014 I would like to fit durite capillary temp gauge 053323 linky to my 300tdi. As I understand it the 300 sender is 1/8th npt and thus difficult to adapt ( ebay says no.) my questions are: Is the thermostat housing thread M22x1.5 And is this location suitable to measure coolant temp from, or do I use the location on top of the head by the rockers that already houses a temp sender, anybody know what this thread is? Thanks, will. Quote Link to comment Share on other sites More sharing options...
western Posted October 19, 2014 Share Posted October 19, 2014 both 1/8npt AFAIK, the sender on top of cylinder head is for the EGR system, Quote Link to comment Share on other sites More sharing options...
Boydie Posted October 21, 2014 Share Posted October 21, 2014 If you dont have air conditioning why not tap out one of the A/C switch plugs on the theremostat housing elbow? that way you can retain the LR temperature guage as well as your Durite unit. Quote Link to comment Share on other sites More sharing options...
muddy Posted October 21, 2014 Author Share Posted October 21, 2014 That's what I was referring to with the m22 thread boydie. Just checking that it's a suitable place to measure coolant temperature, I'm not familiar with the coolant passages in the head. Its in a Tomcat that already has an aftermarket gauge fitted, this appears to read artificially high therefore me wanting to fit this gauge. Will. Quote Link to comment Share on other sites More sharing options...
mickeyw Posted October 21, 2014 Share Posted October 21, 2014 The standard temp sender will be looking at actual coolant temp, irrespective of whether the stat is open or not. IIRC the position of the M22 aircon tapping you refer to will not show the same temp when the stat is closed. Was there not a choice of senders with the Durite gauge? When I bought a VDO unit I could specify the sender thread. Quote Link to comment Share on other sites More sharing options...
Boydie Posted October 24, 2014 Share Posted October 24, 2014 Ok, I disagree, if you use the tapping for the A/C sender then you are measuring the water temperature going to the radiator and AFTER the thermostat, if its well over 100 degrees C then the thermostat is blonked, easy fix, if you're on the road then pull it out or thump a big hole in it to have a constant water flow, if it's in the region of 90 degrees C then all is sweet and the thermostat is regulating the water flow to the radiator as it's designed to Quote Link to comment Share on other sites More sharing options...
