ajh Posted December 7, 2014 Author Share Posted December 7, 2014 TSD but in those cases I would generally expect the rear wheels to be parallel; which is apparently not the case here. Quote Link to comment Share on other sites More sharing options...
reb78 Posted December 7, 2014 Share Posted December 7, 2014 I'll take a measure of mine tomorrow too. Watching what happens here with interest as this problem bugs me from time to time until I forget about it till the next time.... Quote Link to comment Share on other sites More sharing options...
pat_pending Posted December 7, 2014 Share Posted December 7, 2014 It's not unknown for Salisbury axle tubes to bend through heavy impact, especially if overloaded. However it's equally possible the bend (if it exists) is in the stub axle. Before getting over excited you need a proper 4 wheel laser alignment check done, that will tell you if and where any error is located. I know it's a Land Rover but tape measures and string are not that accurate. If the axle itself is bent, they can be straightened, it's a job for an engineering works with a very big press, think large construction plant or steam engines or truck chassis builders. It's also possible to re-tube them if needed. Finally Land Rover build tolerances are huge, you have to go a very long way out to cause problems. The largest cause of handling issues (assuming everything else is in good order) are tyres. Quote Link to comment Share on other sites More sharing options...
ajh Posted December 8, 2014 Author Share Posted December 8, 2014 Against all odds I seem to have located one locally; it needs to be re-assembled but that beats having to ship one. I'll take careful measurements of mine vs the other to determine if it is actually bent. Thanks for all the suggestions. Quote Link to comment Share on other sites More sharing options...
Ex Member Posted December 8, 2014 Share Posted December 8, 2014 Snagger, yeah I was looking at using a D2 housing in the front; not the back. Originally I did want to get Richards to do a chassis with the watts linkage bracket but it was too unusual for them to do at least at the time given their workload. Why would you want to put a D2 front axle on your Defender? Super expensive unit bearings. Expensive drive shafts. Horrible brakes. Quote Link to comment Share on other sites More sharing options...
