DrRob Posted December 12, 2014 Share Posted December 12, 2014 To help with wiring a 200tdi into an old petrol driven 90. Mainly the wiring around glow plugs and fuel stop solenoid etc. Shropshire area. Please PM me Quote Link to comment Share on other sites More sharing options...
qwakers Posted December 12, 2014 Share Posted December 12, 2014 when i did it... stop solenoid to ign live (there are 2 you want the one that stays on when cranking and glow plugs to a button on the dash. ive never needed to use them... Quote Link to comment Share on other sites More sharing options...
steve b Posted December 12, 2014 Share Posted December 12, 2014 The White wire that was plugged into the +ve side of the coil goes to the fuel stop solenoid The glow plug relay is pretty easy too , if you have the relay socket with the wires in it , the heavy brown goes to the battery , the heavy black/yellow goes to the HP's , the small black/yellow goes to the choke warning light wire , the white goes to the ignition live - you can use the same one as the IP stop solenoid and the black is earth . hth Steveb Quote Link to comment Share on other sites More sharing options...
