Defender Posted March 7, 2015 Share Posted March 7, 2015 Hi Everyone, I was wondering if someone may be able to help me. I need to fit a 228mm clutch to an LT95 gearbox (OM606 conversion), I was told that to get a 228mm plate the right size I needed to order a series, 9 inch clutch plate because this is 10 spline. I've done this but the plate seems to move on the splines, although the splines aren't wide enough. Is there a difference in the splines between the RR Classic and the Series clutch plate? Or have I ordered the wrong part, the code is 591704. I can't find anything that mentions the spline diameter it always just seems to mention the centre size e.g. 10 spline 1 inch 1/8th. Thanks, Quote Link to comment Share on other sites More sharing options...
tacr2man Posted March 7, 2015 Share Posted March 7, 2015 IIRC landrover gearbox are only two sorts of spline fine (later gearboxes) and the coarse all the early gearboxes eg lt95 4 speed , series gearboxes . 8510290 is the 9.5 inch 591704 is the 9 inch Quote Link to comment Share on other sites More sharing options...
