DC_ Posted April 7, 2015 Share Posted April 7, 2015 Hello once again to everyone. MOT Time again and yes you guessed it, my bottom oil cooler pipe perished. Pin hole in the rubber pipe which resulted in much oil scooshing all over my manifolds etc. Could someone help me get the correct part and maybe a step by step guide to what's involved to do it. The light nights are here so want to try get as much done as possible before it's due in. Cheers folks, as usual much appreciated ?? Quote Link to comment Share on other sites More sharing options...
DC_ Posted April 8, 2015 Author Share Posted April 8, 2015 Ok I've managed to get the pipes off. Now need to make sure I source the right ones to replace. Anyone help with part numbers?? Quote Link to comment Share on other sites More sharing options...
duncmc Posted April 8, 2015 Share Posted April 8, 2015 From your description I am not too clear on which of the pipes has split. Which number is it, and if I don't get there first some one else might reply first with a part number. Quote Link to comment Share on other sites More sharing options...
DC_ Posted April 8, 2015 Author Share Posted April 8, 2015 Thanks duncmc for the reply. The pipes aren't on that diagram. I think that looks like auto transmission fluid pipes? It's for the oil itself that runs round the engine. Attached to the radiator and then run to oil adaptor on the oil filter. Cheers Quote Link to comment Share on other sites More sharing options...
duncmc Posted April 8, 2015 Share Posted April 8, 2015 R......got it now, the light dawns...That's what puzzled me, I was thinking "they are both at the bottom". There are two sets of part numbers listed. Up to engine no 36D52437, the bottom hose is ESR2813 and the top hose is ESR2814. Then from 36D52438 its ESR3692 for the bottom and ESR3693 for the top. I would get some new O rings too. They are listed as O ring ESR1594L which is number 4 on the diagram, and then ESR1594L and ESR3098 (small O ring) for number 2 on the diagram. Hope that helps. Quote Link to comment Share on other sites More sharing options...
DC_ Posted April 8, 2015 Author Share Posted April 8, 2015 Thanks again duncmc But, ( I hate a but) this looks like 300tdi oil cooler pipes? The reason I say is the ends don't look the same as mine. Mines are tapered and I'm sure the pirtek guy told me they are half inch bsp female connections for my V8 3.9. I've seen second hand ones on eBay along with the oil adaptor which look like mine. I have "the fear" that its not Gona be cheap Quote Link to comment Share on other sites More sharing options...
duncmc Posted April 8, 2015 Share Posted April 8, 2015 Those numbers are for the 3.9V8. Hence the engine numbers. Quote Link to comment Share on other sites More sharing options...
duncmc Posted April 8, 2015 Share Posted April 8, 2015 A quick Google, and from Britcar as an example. It says ESR2813 has been superceeded by PBO101160. they list a genuine part as £60.91 plus VAT, and an a Bearmach one for £12.68+VAT. Quote Link to comment Share on other sites More sharing options...
DC_ Posted April 8, 2015 Author Share Posted April 8, 2015 Don't see any of those part numbers matching my pipes. They all have the same pipe diagram that's in your previous diagram. I don't have O rings on my pipes either Quote Link to comment Share on other sites More sharing options...
DC_ Posted April 8, 2015 Author Share Posted April 8, 2015 Yeh I see the same. I'll try get a picture up tomorrow of my pipes. These are not the same connections as mine. Quote Link to comment Share on other sites More sharing options...
duncmc Posted April 8, 2015 Share Posted April 8, 2015 Don't see any of those part numbers matching my pipes. They all have the same pipe diagram that's in your previous diagram. I don't have O rings on my pipes either Has it been modified at some point then, maybe? Quote Link to comment Share on other sites More sharing options...
DC_ Posted April 8, 2015 Author Share Posted April 8, 2015 Nope, this is the closest I can find but was hoping someone would confirm it..... NTC5620 also britpart showing at £76. Quote Link to comment Share on other sites More sharing options...
DC_ Posted April 8, 2015 Author Share Posted April 8, 2015 http://www.brit-car.co.uk/product.php/88946/5497/oil_cooler_pipe_3_9efi_auto_rrc__fa Quote Link to comment Share on other sites More sharing options...
duncmc Posted April 8, 2015 Share Posted April 8, 2015 Microcat shows NTC5620 to be the oil cooler pipe upto chassis FA399972, so maybe its been changed before for a second hand one? If your car is a 1992, it should be later than FA399972 definately. Quote Link to comment Share on other sites More sharing options...
DC_ Posted April 8, 2015 Author Share Posted April 8, 2015 My chassis is a JA ..... Yes I suppose this is possible. my heads thumping. I'll sleep on it and do more tomorrow. Cheers Quote Link to comment Share on other sites More sharing options...
Cookee Posted April 10, 2015 Share Posted April 10, 2015 I need to replace the two pipes 12 and 13 on the diagram with flexible ones so that I can re route them in order to fit a winch on the front - anyone have any bright ideas? Thanks! Quote Link to comment Share on other sites More sharing options...
