Paul64 Posted November 10, 2006 Share Posted November 10, 2006 Hi, I noticed in a heavy downpour that a small amount of water appears under the rear bench seat. At first I thought it may be coming through the body seal as looks a bit cracked. However, this must be quite a wide seal, so unlikely to leak. The only other possibility that I can see is the side rear window seal. Are these known to be a weak spot? If it needs changing is this a difficult job? Cheers, Paul. Quote Link to comment Share on other sites More sharing options...
western Posted November 10, 2006 Share Posted November 10, 2006 It'll be a complete window out job, remove the rubber filler strip & drill out all the rivets, then carefully remove the window assembly, to remove the centre vertical seal strip, there's a screw at each end,you'll see it in the frame edge, there's a seal MUC1008 between the window frame & body panel, the vertical seal strip MWC7614 & the felt strip MUC3096, any or all of these could let water into the rear interior, obviously the vehicle will need 2 of each, plus lots of rivets to refit the assemblies Quote Link to comment Share on other sites More sharing options...
Paul64 Posted November 10, 2006 Author Share Posted November 10, 2006 It'll be a complete window out job, remove the rubber filler strip & drill out all the rivets, then carefully remove the window assembly, to remove the centre vertical seal strip, there's a screw at each end,you'll see it in the frame edge,there's a seal MUC1008 between the window frame & body panel, the vertical seal strip MWC7614 & the felt strip MUC3096, any or all of these could let water into the rear interior, obviously the vehicle will need 2 of each, plus lots of rivets to refit the assemblies Thanks for that Quote Link to comment Share on other sites More sharing options...
western Posted November 10, 2006 Share Posted November 10, 2006 Paul64 said: Thanks for that forgot the rivets part number you'll need 48 for both sides there are 24 per side of RU610313L & if you need the 4 small screws for the centre vetical bar their part number is AC606081L Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted November 10, 2006 Share Posted November 10, 2006 Hi,I noticed in a heavy downpour that a small amount of water appears under the rear bench seat. Cheers, Paul. In that case, i'd just sit back and consider yourself lucky!!! Quote Link to comment Share on other sites More sharing options...
Paul64 Posted November 10, 2006 Author Share Posted November 10, 2006 In that case, i'd just sit back and consider yourself lucky!!! I take that to mean it is quite a common minor problem? Quote Link to comment Share on other sites More sharing options...
Paul64 Posted November 11, 2006 Author Share Posted November 11, 2006 Checked the bottom drainage vents. All clear. Noticed near side lower seal a bit porous. Looks like the offending article. Seems like a big job Western for one single strip of seal. I have just smeared some grease along it for now. Will have to think about a full seal change. I can drill out the rivets, but have none to replace or a rivet gun yet. I take it a LR specialist would clear out my bank balance if I asked them to do it? Quote Link to comment Share on other sites More sharing options...
western Posted November 11, 2006 Share Posted November 11, 2006 Most likely a LR specialist would want a fair chunk, it's a bit of a time consuming job. Quote Link to comment Share on other sites More sharing options...
Guest dew110CSW Posted November 11, 2006 Share Posted November 11, 2006 With older Landies, instead of fixing the leak, simply drill a hole to give the water somewhere to go... Quote Link to comment Share on other sites More sharing options...
V8 Freak Posted November 11, 2006 Share Posted November 11, 2006 I thought it was compulsory that you had to have leaks !!! (Wasn't it in the design specs ?) Quote Link to comment Share on other sites More sharing options...
Paul64 Posted November 11, 2006 Author Share Posted November 11, 2006 I thought it was compulsory that you had to have leaks !!!(Wasn't it in the design specs ?) Yours looks too clean to have leaks! It is a real pain though, as the paint work is bubbling up beneath the leak inside and out. I was out pm in the LR, and took some pics of the offending area. Too Mildly miffed to load up now, so will do it mane. Quote Link to comment Share on other sites More sharing options...
Paul64 Posted November 11, 2006 Author Share Posted November 11, 2006 With older Landies, instead of fixing the leak, simply drill a hole to give the water somewhere to go... Mine does have drain outlet, so can't be too old! Quote Link to comment Share on other sites More sharing options...
Paul64 Posted November 11, 2006 Author Share Posted November 11, 2006 Hi Western, Bought the rivet gun and rivets. Didn't have time to do the window today, but replaced all the corroded rivets on the lower door seal which is leaking. Getting a bit of practice in before the big job! Quote Link to comment Share on other sites More sharing options...
western Posted November 11, 2006 Share Posted November 11, 2006 blimey, your keen I've got to change those seals front & rear on my 110 too, got the bits but need to clean up & paint the channels first, maybe one day I'll get round to it Quote Link to comment Share on other sites More sharing options...
Paul64 Posted November 11, 2006 Author Share Posted November 11, 2006 blimey, your keen I've got to change those seals front & rear on my 110 too, got the bits but need to clean up & paint the channels first, maybe one day I'll get round to it Yes, The mud and water piling in today. Found a local army range to do a bit of off roading on. On my way back home bought the rivet kit and got straight down to business. Drilled out old rivets, dropped sill, cleaned up mess, dried it off, lined with silicone, replaced seal, riveted, replaced sill. Done in 1.5 hours. Would have been quicker, but all sill bolts corroded on which were a bit of a pig to get off. Quote Link to comment Share on other sites More sharing options...
Paul64 Posted November 12, 2006 Author Share Posted November 12, 2006 Here is a photo as discussed. As you can see it really is eating into the bodywork Quote Link to comment Share on other sites More sharing options...
Paul64 Posted November 12, 2006 Author Share Posted November 12, 2006 How do you insert photos with text rather than create links anyone? HELP Quote Link to comment Share on other sites More sharing options...
western Posted November 12, 2006 Share Posted November 12, 2006 How do you insert photos with text rather than create links anyone? HELP in the 'full edit' box, there's a small icon of a tree [8th from the left] click on that & enter your link [must be hosted on a website or in the gallery of this site] to your picture, then click 'preview post' if it's all there then click 'add reply' Quote Link to comment Share on other sites More sharing options...
Paul64 Posted November 12, 2006 Author Share Posted November 12, 2006 in the 'full edit' box, there's a small icon of a tree [8th from the left] click on that & enter your link [must be hosted on a website or in the gallery of this site] to your picture, then click 'preview post' if it's all there then click 'add reply' Did it, didn't work. All that does is review the link. How do you get the actual picture in the post rather than the link? Quote Link to comment Share on other sites More sharing options...
Paul64 Posted November 12, 2006 Author Share Posted November 12, 2006 This is the problem. Whenever i try and insert the image fro web host this message comes up. Sorry, dynamic pages in the tags are not allowed What does this mean in English? Quote Link to comment Share on other sites More sharing options...
western Posted November 12, 2006 Share Posted November 12, 2006 (edited) I see what's happening, the link you have above is a dynamic link, for some reason this site won't let those type work, can't remember how I got past it last time, I can put your pic on my Photobucket pages if you like, it'll work then. Edited November 12, 2006 by western Quote Link to comment Share on other sites More sharing options...
western Posted November 12, 2006 Share Posted November 12, 2006 This is the problem. Whenever i try and insert the image fro web host this message comes up.Sorry, dynamic pages in the tags are not allowed What does this mean in English? seems that your photobox site doesn't allow hot linking, except by inserting a link like you have already done above, I can't get it to work either you can upload the picture to the gallery from your profile 'My Controls' & then link to it from your post Quote Link to comment Share on other sites More sharing options...
Paul64 Posted November 12, 2006 Author Share Posted November 12, 2006 Thanks Ralph, I opened an account with Photobucket. It works fine from there. I have now edited my message. What do you think of the damage caused by the leak? Quote Link to comment Share on other sites More sharing options...
western Posted November 12, 2006 Share Posted November 12, 2006 Thanks Ralph,I Opened an account with Photobucket. It works fine from there. I have now edited my message. what do you think of the damage caused by the leak? not unusual damage the water/moisture has got under the paint & corroded the body capping, these cappings used to be galvanised but were changed to non-gal, which lets this happen, is that at the forward end around the welded joint ? a good clean off, treat & repaint will sort it. Quote Link to comment Share on other sites More sharing options...
Paul64 Posted November 12, 2006 Author Share Posted November 12, 2006 not unusual damage the water/moisture has got under the paint & corroded the body capping, these cappings used to be galvanised but were changed to non-gal, which lets this happen, is that at the forward end around the welded joint ? a good clean off, treat & repaint will sort it. Yes, it is at the forward end, but is also at the rear and the same two points on the other side. Repair job on the list for a dry and less cold day. Cheers, Paul. Quote Link to comment Share on other sites More sharing options...
