Anglo-Frenchman Posted June 19, 2015 Share Posted June 19, 2015 Hi. I'm looking for a bulb for the climate control unit in my 2002 Disco. I've had the unit out and it's a non standard type thing with a rubber cover over the bulb. Not easy to find here in NZ unless you want a second mortgage. Thanks. Quote Link to comment Share on other sites More sharing options...
teabag Posted June 19, 2015 Share Posted June 19, 2015 If it not brittle remove the rubber cover, the down to your local electronics store and find a a similar bulb, some bulbs just have tails so u can reuse the existing base, then reuse the your existing cover. Better to use this link for the pt no. And search locally I would have thought http://www.allbrit.de/NAV.cfm?SPRACHE=EN&PAGE=536838 Quote Link to comment Share on other sites More sharing options...
Boydie Posted June 20, 2015 Share Posted June 20, 2015 If you can show me a photo I can probably get one locally here in Australia and post it to you Quote Link to comment Share on other sites More sharing options...
teabag Posted June 20, 2015 Share Posted June 20, 2015 This Forum link may help http://www.landyzone.co.uk/lz/f8/discovery-2-climate-control-illumination-bulb-options-258545.html Quote Link to comment Share on other sites More sharing options...
Anglo-Frenchman Posted June 27, 2015 Author Share Posted June 27, 2015 If you can show me a photo I can probably get one locally here in Australia and post it to you Thanks very much for the offer but I've ordered some through the local dealer. Not as expensive as is expected. Quote Link to comment Share on other sites More sharing options...
