Hybrid_From_Hell Posted November 14, 2006 Share Posted November 14, 2006 Hello All. Anmyone know whwere I can get this stuff from, FORTE Specialist injector cleaner P/N 42217 ? GU postcode would be superb ! ? Nige Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted November 14, 2006 Share Posted November 14, 2006 Any motor factors? Pretty sure my local chaps have it on the shelf. Redex will probably work just as well. Is this a grasping-at-straws misfire hunt by any chance? BTW if you have a 9th injector, have you tried disconnecting it (and its fuel pipe). Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted November 14, 2006 Author Share Posted November 14, 2006 No Motor factors I have rung around ARE CAF WHOOPEE none have it - motor trade accounts now only Have just had a text from mate in mit source - phone call coming. Clutching at straws ? Me ? Yep absolutely..... but... A couple of knowledgable mate have sqeaked "Injectors" from my limited knowledge on them there can be either an elecritcal problem / ie not working due to injector not fireing / short circuit, but the other is that the injectors can get gummed up abnd instead of spraying an atomized mist of fuel it "Squirts! and then the fuel in in the chamber but cna't ignite, this can have werierd effects all around the enhine.. as such for the sake of 2x bottles of this and a blast about it might just have zero effect, BUT if it has a mild effect or cures it then I may be onto something, in which case its tear engine apart for ultrasoniocally cleaned injectors.. For the sake of a few quid to try has to be worth a go ? I have another set of Eales / Jag Injectors, so may get them done in advance anyway.... Nige Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted November 14, 2006 Share Posted November 14, 2006 Even Halfrauds sell Forte & Redex Since you have the spare set of injectors just get 'em cleaned and bung 'em in, it's not *that* much arse ache to change injectors and even if you don't cure it you have sparkly new injectors in. B) Quote Link to comment Share on other sites More sharing options...
dollythelw Posted November 14, 2006 Share Posted November 14, 2006 tried giving them the ultrasonic clean treatment Nige? the diesel (had to get that in sorry mate ) injection specialists will clean and spray pattern them for you for not a heap of cash Quote Link to comment Share on other sites More sharing options...
