mudmagnet Posted August 14, 2015 Share Posted August 14, 2015 What should a ps pump feel like when you spin the pulley by hand should it spin freely or should there be some resistance. Mine turns by hand but is a little stiff and notchy Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted August 14, 2015 Share Posted August 14, 2015 Should be smooth with slight resistance but not much. Quote Link to comment Share on other sites More sharing options...
oneandtwo Posted August 14, 2015 Share Posted August 14, 2015 More importantly check for end float - see if the pulley can be pulled in and out of the pump. Once it has begun it just gets worse and the belt tends up running up to or over the pulley flange and trashing the belt. Quote Link to comment Share on other sites More sharing options...
Boydie Posted August 16, 2015 Share Posted August 16, 2015 "Notchy" ?? I think your PS pump front ball bearing is kaput. This would give it a "notchy" feel as the pulley is turned, it should be smooth but with resistance as it's trying to pump the transmission fluid. Quote Link to comment Share on other sites More sharing options...
mudmagnet Posted August 17, 2015 Author Share Posted August 17, 2015 It's smooth if I just turn slow but can feel slight lumpiness when turned faster Quote Link to comment Share on other sites More sharing options...
Boydie Posted August 23, 2015 Share Posted August 23, 2015 I still think that the front bearing has gone, it baffles me why the bearings in this pump are not lubricated by the transmission fluid with a ceramic mechanical seal external to the front bearing - obviously too sensible for LR to specify when they built the 300Tdi. Quote Link to comment Share on other sites More sharing options...
Sheffield Posted August 24, 2015 Share Posted August 24, 2015 I suspect the design of the pump was in the hands of the pump maker who supplied them to LR, not LR. Quote Link to comment Share on other sites More sharing options...
Boydie Posted August 29, 2015 Share Posted August 29, 2015 Sheffield, your'e probably right, but ultimately the design criteria comes down to LR, if they specified a certain design then they would have been supplied it, unless of course the dreaded bean counters (accountants) decided to go for the cheaper option, which is quite common. Quote Link to comment Share on other sites More sharing options...
