mike4444244 Posted August 16, 2015 Share Posted August 16, 2015 Hi I'm in the middle of changing the timing belt on a 300 and bought new tensioner and idler pulleys, but they didn't come with new fixings, can I just re-use the stud and get a new nut and bolt or does the panel recommend replacing, if so is there a part number for them? Also are the updated crank pulleys one piece, ie the guide isn't spot welded on? Ta Mike Quote Link to comment Share on other sites More sharing options...
western Posted August 16, 2015 Share Posted August 16, 2015 item 7 in http://lrcat.com/#31/4/53198 Quote Link to comment Share on other sites More sharing options...
Les Henson Posted August 17, 2015 Share Posted August 17, 2015 I've only ever used Bearmach kits and the crank sprocket is the one piece type. I guess you would have to ask the supplier. It's ok to use the old stud, but use a new nut (nyloc). Les Quote Link to comment Share on other sites More sharing options...
mike4444244 Posted August 17, 2015 Author Share Posted August 17, 2015 thanks chaps Quote Link to comment Share on other sites More sharing options...
