zippone Posted October 16, 2015 Share Posted October 16, 2015 Hello everybody, I'm a new-by and happy to join this forum, I 've been driving this Freelander for over a year fine, and now I'm having heavy vibrations, starting as soon as I shift into second gear and push onto the gas pedal, the more the power traction the more severe the vibrations, with the gear lever shaking from left to right. I had the propshaft pulled off and a test drive without the propshaft was fine, no vibrations at all.What could be? My mechanic has no clue at all, he blames the shaft, but everything seems to be ok with the bearings, could be a faulty VCU? Car has quite hi mileage, about 110.000 miles, but is providing good service for the rest.Thanks to everybody for the help Quote Link to comment Share on other sites More sharing options...
tim_roberts Posted October 17, 2015 Share Posted October 17, 2015 I would suspect the vcu mounting bearings first. Or just leave the propshaft off! Quote Link to comment Share on other sites More sharing options...
siral Posted October 17, 2015 Share Posted October 17, 2015 I had the same problem with a Freelander i had a while ago took the prop of and ran it that way for years with no probs Quote Link to comment Share on other sites More sharing options...
zippone Posted October 17, 2015 Author Share Posted October 17, 2015 thanks for your replies gentlemen, but it snows quite a lot where I live, so I need the 4x4, otherwise why buying a Freelander? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted October 19, 2015 Share Posted October 19, 2015 Check all the engine / transmission mounts, could also be loose driveshafts (CV joints) wobbling. Quote Link to comment Share on other sites More sharing options...
zippone Posted October 21, 2015 Author Share Posted October 21, 2015 thanks, I checked the propshaft CV coupling, the one in front of the shaft, it has some play, hard to tell if it's excessive or normal, I'll try to check some more Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted October 21, 2015 Share Posted October 21, 2015 Check the driveshafts to the wheels too, they have 2 CV joints each. Quote Link to comment Share on other sites More sharing options...
zippone Posted October 22, 2015 Author Share Posted October 22, 2015 Check the driveshafts to the wheels too, they have 2 CV joints each. before doing what you suggested, I checked the propshaft CV coupling, which has some play, but not sure if that is normal or not, a probably should compare it with some other, I'll see how I could do this Quote Link to comment Share on other sites More sharing options...
Hoady Posted December 10, 2015 Share Posted December 10, 2015 Hi,did you find the problem as I have a similar one? Quote Link to comment Share on other sites More sharing options...
zippone Posted December 14, 2015 Author Share Posted December 14, 2015 yes!! I solved the problem replacing the front propshaft with the CV , and, like magic, the car was running smooth and fine at all speeds! fantastic, I was very happy! propshaft costed €169 + shipping, and mechanic charged me only €30 for replacement, very good, seller was Carspares, England off course, they ship on the same day. Thanks to all people who helped me with this problem! Quote Link to comment Share on other sites More sharing options...
Hoady Posted December 14, 2015 Share Posted December 14, 2015 Thanks for your reply I'll give it a try. P's Happy Christmas. Quote Link to comment Share on other sites More sharing options...
