Nigelw Posted October 26, 2015 Share Posted October 26, 2015 Got a bit over zealous with the removal of the air filter on the 200Tdi, been in and out a few times in the last 10,000kms but today the rubber seal was stuck solid! 10mins drifting it out with a bit of wood But now the back end is galled up a bit as I was leavering and beating it around What to do now? I can get by with it for now but should I look to replace it with another tin can or is there something better out there? I had thought 300Tdi style but I have a second battery and a fuse board with relays where the actual airbox would sit. suggestions..... Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted October 26, 2015 Share Posted October 26, 2015 As long as it uses a paper filter element, go for it. I would go with standard to be honest, you have nothing much to gain, just seal it up well this time, as you mentioned snorkel recently... Quote Link to comment Share on other sites More sharing options...
Nigelw Posted October 27, 2015 Author Share Posted October 27, 2015 Hadn't considered the future snorkel fitting TBH (feels a bit silly ) What better suits a snorkel fit on a D1 then, plastic box or tin can type? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted October 27, 2015 Share Posted October 27, 2015 Well... given you have a battery where the plastic one would go, I would say the tin can! Easier to weld up and seal a metal one compared to plastic, well imho. Quote Link to comment Share on other sites More sharing options...
Nigelw Posted October 27, 2015 Author Share Posted October 27, 2015 Right then, look for new tin can whilst fettling this one into some sort of shape again. Do you think I could find neoprene seals to seal between filter housing and filer base? Something 5~8mm thick? be a good start if I can't find a good used one Quote Link to comment Share on other sites More sharing options...
hangover Posted October 28, 2015 Share Posted October 28, 2015 Not sure about snorkle's there but i have a safari snorkle with square filter box and the largest battery you can fit in the aux. tray (105AH dual purpose crank / deep cycle ). Quote Link to comment Share on other sites More sharing options...
