leejunfan1 Posted December 12, 2015 Share Posted December 12, 2015 Defender 200 TDI 1991 After many hours fault finding, the rear screen is drawing over 6Amps with engine off. I have removed the fuse and now the drain has gone, i have found a few bits on Google about it but none confirm if my year of defender has a relay for it that could be causing the short. Pulling the switch still leaves the drain. If there is a relay, where is it and what part number is it, any pics would help? Any info would be much appreciated! Quote Link to comment Share on other sites More sharing options...
Hazza Posted December 12, 2015 Share Posted December 12, 2015 No photos but there is a relay, it takes a feed from a voltage sensing relay before it'll operate. Mine (1990 200tdi) is located behind and below the dash binnacle. Quote Link to comment Share on other sites More sharing options...
western Posted December 12, 2015 Share Posted December 12, 2015 heated screen relay sits in front right corner of dash next to the voltage sensitive switch [aka big yellow case relay] you can access by removing the instument pack or via the lower dash speaker hole if they are fitted. Quote Link to comment Share on other sites More sharing options...
