Mo Murphy Posted December 15, 2015 Share Posted December 15, 2015 On a 200 Tdi. Can it be done in situ with the exhaust removed or does the starter motor need to come out ? Mo Quote Link to comment Share on other sites More sharing options...
Maverik Posted December 16, 2015 Share Posted December 16, 2015 Hey Mo, I seem to remember trying to do this on a my disco 200tdi and got fed up as it was a bit fiddly so I just pulled the motor out and did it on the bench. Most of them require just two smallish nuts or screws to be removed but it's something like an 8mm AF nut so pretty fiddly. You're pretty much half way there having the exhaust off for the effort I'd probably just pull the motor, give it a bit of a clean and a health check... Quote Link to comment Share on other sites More sharing options...
