mcc1979ian Posted January 22, 2016 Share Posted January 22, 2016 Evening gents. This is probably been asked many times before but I can't seem to find the answer anywhere. Iv bought a RRC efi pump to run my 4.6 in my 90, I have a standard 2 hole side mounted tank but I'm unsure how much I need to extend the pump by to reach the bottom. Would anyone have pics and dimensions to hand or a link to the info I need please. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted January 22, 2016 Share Posted January 22, 2016 Just drop a 600mm steel rule in the tank? Quote Link to comment Share on other sites More sharing options...
mcc1979ian Posted January 22, 2016 Author Share Posted January 22, 2016 Does the pump touch the bottom of the tank when in use? Or should i keep it slightly shorter? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted January 22, 2016 Share Posted January 22, 2016 5mm shorter will be fine Quote Link to comment Share on other sites More sharing options...
steve200TDi Posted January 23, 2016 Share Posted January 23, 2016 That's what I did. Just shy of the bottom of the tank. Here's my build thread here: http://forums.lr4x4.com/index.php?showtopic=87607&p=754164 It may have some useful pictures for you. Oh and remember when you extend it, you'll probably be needing a longer bit of fuel hose. Remember it has to be fuel hose that's fuel resistant of the inside as well as the outside! Steve Quote Link to comment Share on other sites More sharing options...
