Anderzander Posted May 4, 2016 Share Posted May 4, 2016 Did windscreen frames change at all ? I read a post on here that showed two different part numbers so I'm assuming at a certain year they changed to accomodate the interior light moving? Anyone know the year? The one on my Td5 is a bit ropey. Quote Link to comment Share on other sites More sharing options...
western Posted May 4, 2016 Share Posted May 4, 2016 interior light bracket is on the inside of the roof NOT part of screen frame, LR frequently update older 7 digit part numbers on a model update or to longer 9 digit numbers. [the current format] see item 1 in http://www.allbrit.de/UNI.cfm?PAGE=764634&SPRACHE=EN click on the + to get the part numbers. other alternative is remove the frame from vehicle, get it cleaned/treated/repainted & refit. it's not a part that suffers from 'normal ferrous rust' as it's a alloy casting. not steel. Quote Link to comment Share on other sites More sharing options...
Anderzander Posted May 4, 2016 Author Share Posted May 4, 2016 That's promising then - thank you Ralph. Mine has been drilled a bit untidily for a snorkel. The rubber is a bit knackered and the screen has a small chip - so the plan is to pick up a frame, get it painted, fit a heated screen with a new rubber, and then swap them over. Quote Link to comment Share on other sites More sharing options...
