SJL1959 Posted August 15, 2016 Share Posted August 15, 2016 Hi All, I have a L plate 200tdi Discovery that is currently running a 1 inch lift on Britpart gas shocks and springs. The vehicle no longer offroads, but I'd like to maintain the lift and have a more comfortable and forgiving ride on the road. Any suggestions for the suspension I could change to ? ( I have an anti roll bar fitted ) Thanks, Steve Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted August 15, 2016 Share Posted August 15, 2016 Stock springs and shocks plus inch spacer blocks? Quote Link to comment Share on other sites More sharing options...
honitonhobbit Posted August 15, 2016 Share Posted August 15, 2016 Go OEM spec springs - Yellow/Yellow and white/white on the rear with Red/Yellow and Green/Yellow on the front OEM Delphi Gas Shocks are brilliant SuperPro Bushes all round Replace the bolts on the 'A' arm to chassis mounts at the same time Quote Link to comment Share on other sites More sharing options...
honitonhobbit Posted August 15, 2016 Share Posted August 15, 2016 To gain height use Gwynn Lewis spacers Quote Link to comment Share on other sites More sharing options...
SJL1959 Posted August 15, 2016 Author Share Posted August 15, 2016 Stock springs and shocks plus inch spacer blocks? Thanks Bowie69 Quote Link to comment Share on other sites More sharing options...
SJL1959 Posted August 15, 2016 Author Share Posted August 15, 2016 Go OEM spec springs - Yellow/Yellow and white/white on the rear with Red/Yellow and Green/Yellow on the front OEM Delphi Gas Shocks are brilliant SuperPro Bushes all round Replace the bolts on the 'A' arm to chassis mounts at the same time Thanks honitonhobbit Quote Link to comment Share on other sites More sharing options...
