300tdi Water Pump Bracket
Is the water passage way in the water pump bracket ERR3736 coated, or does it come bare aluminum. Mine is off right now and appears to have an orange/green color and I’m not sure if that’s a coating or staining from coolant.
The reason I ask is mine needs repair on the mating surface to the water pump. Was thinking about having it tig welded but concerned that the heat may damage the coating if it were coated. Does anyone know? The alternative would be an epoxy repair.
Cheers in advance,
