nico3dd Posted October 24, 2016 Share Posted October 24, 2016 I haven't found the info i need between thousand of read pages.. so i just though of posting this here. any help would be greatly aprecciated. so i just got lucky, and a friend was tossing his td5 r380 gearbox, which obviously i wasnt going to let that happen. So i had an old lt77 suffix E which has some synchro problems. Is the input shaft from the lt77 interchangeable with the r380 one? i know the td5 r380 input shaft measures 22mm ish diameter and a bout 350 mm ish long, (measured from the front face of the 4th gear pinion) I have acces to a lathe and can modify the input shaft if needed. What are the exact measures im looking for?? what about the bell housing? could i use the lt77 one? Quote Link to comment Share on other sites More sharing options...
