dicsosfa Posted September 19, 2009 Share Posted September 19, 2009 hi all can anyone tell me if a m reg discovery 300tdi should have a 3 pin or a 4 pin indicator relay as i am trying to solve a problem with my trailer warning light not working ,bulbs ok indicators working on car,caravan and trailer have been told it should have an extra pin for the warning light. having checked mine tonight and it is a lucas 53988076a 3 pin type does anyone know the part number for the correct 4 pin indicator relay ? thanks Roy Quote Link to comment Share on other sites More sharing options...
western Posted September 19, 2009 Share Posted September 19, 2009 4 pin type here PRC8876 or it might be this one here Quote Link to comment Share on other sites More sharing options...
cipx2 Posted September 19, 2009 Share Posted September 19, 2009 It's like this: - if the LR left the factory without a towing pack fitted, it should have the 3 pin flasher relay - if the towing pack was fitted from factory or later as a complete kit (the 4 pin flasher relay is part of the kit), it should have the 4 pin relay. - if the towing kit wasn't exactly a kit, was retrofitted using SH or non genuine bits or whoever fitted a genuine kit forgot or "forgot" to replace the relay then you ended up with the 3 pin version. - if, regardless of previous three cases, one of the previous owners or electricians working on the vehicle replaced a faulty relay with the 3 pin version then this is what you currently have. If your LR has indicators in the rear bumper as well (I don't think so) then the PRC8876 is no good as it needs to carry 8 x 21W (+ the rest of the smaller bulbs) and it's rated only up to 6 x 21W. If your LR doesn't have the extra 2 indicator lights in the rear bumper then the PRC8876 should be fine. AMR4873 it's rated between 4x21W+5W+1.2W and 8x21W+2x5W+2x1.2W so it covers both cases (with/without extra indicators in the bumpers). Microcat indicates YWL10002L but it has the same ratings as the PRC8876 (only 6x21W + the rest). Quote Link to comment Share on other sites More sharing options...
ThreeSheds Posted September 20, 2009 Share Posted September 20, 2009 It's like this: - if the LR left the factory without a towing pack fitted, it should have the 3 pin flasher relay - if the towing pack was fitted from factory or later as a complete kit (the 4 pin flasher relay is part of the kit), it should have the 4 pin relay. - if the towing kit wasn't exactly a kit, was retrofitted using SH or non genuine bits or whoever fitted a genuine kit forgot or "forgot" to replace the relay then you ended up with the 3 pin version. - if, regardless of previous three cases, one of the previous owners or electricians working on the vehicle replaced a faulty relay with the 3 pin version then this is what you currently have. If your LR has indicators in the rear bumper as well (I don't think so) then the PRC8876 is no good as it needs to carry 8 x 21W (+ the rest of the smaller bulbs) and it's rated only up to 6 x 21W. If your LR doesn't have the extra 2 indicator lights in the rear bumper then the PRC8876 should be fine. AMR4873 it's rated between 4x21W+5W+1.2W and 8x21W+2x5W+2x1.2W so it covers both cases (with/without extra indicators in the bumpers). Microcat indicates YWL10002L but it has the same ratings as the PRC8876 (only 6x21W + the rest). The above is and example of what constantly impresses me about this forum - the members who go the extra mile and answer questions with detailed, accurate and extensive information - you know who you are guys - THANKS from the rest of us! Quote Link to comment Share on other sites More sharing options...
dicsosfa Posted September 20, 2009 Author Share Posted September 20, 2009 hi i have to agree with treesheds its members like these (cipx2) and others with vast kwow how that make it a pleasure to have faults any how back to the problem my disco has only 2 indicators in the rear bumper its a 1994 model so i can use either again a big thanks for all the help Roy Quote Link to comment Share on other sites More sharing options...
dicsosfa Posted September 20, 2009 Author Share Posted September 20, 2009 hi i managed to get it sorted took a trip the local breakers and got a couple of four pin relays 1 x 6 21w from a m reg and 1 8x21w from a p reg for a mere £1 thanks to all those that replied. Roy. Quote Link to comment Share on other sites More sharing options...
