TD5 Discovery leaking roof - roof rails to blame?
  • Please log in to reply
3 replies to this topic
#1 boaterboy
boaterboy
    Member
  • Settled In
  • PipPip
  • 166 posts
Posted 06 July 2010 - 11:13 AM
Does anyone know if a bad join between the roof rails and the roof panel could be the source of a leak?
How are the joins constructed?
On my car there appears to be a foam rubber gasket which looks to have gone brittle.
The roof rails are evidently not pulled down tight on the gasket and the rails are firm on the roof panel which leads me to wonder if there is a spacer of some sort?
Any help, advice, diagrams, etc. would be gratefully received as a contribution to stopping a wretched roof leak!
By taping up the joins I've established it's neither between the glass / seal nor the sunroof plastic surround / roof panel.
#2 nicks90
nicks90
    Old Hand
  • Settled In
  • PipPipPip
  • 1,456 posts
Posted 06 July 2010 - 12:01 PM
check the alpine windows as well - they have a habit of leaking past the seal.
WWW.YORKSHIREOFFROADCLUB.NET
Familly friendly 4x4 club. Monthly RTVs, nav scatter, clubman challenges and pub meets.
#3 dooroy
dooroy
    Old Hand
  • Settled In
  • PipPipPip
  • 210 posts
Posted 06 July 2010 - 12:23 PM
Apparently there are a number of possibilities for leaks - that was why I took out the headlining and left it out for 2 months to satisfy myself as to where the leaks were .In my case between the sunroof frame and the vehicle roof .
The alpine windows are bonded in the D2 but I suppose they can still leak .
Some have also reported a leak from the roof gutter area - the join where the roof meets the rest of the vehicle .
Roof bar attachment points not a common source .
The roof lining while in place can carry water in all directions and make a leak very difficult to pinpoint .
#4 teabag
teabag
    Old Hand
  • Settled In
  • PipPipPip
  • 989 posts
Posted 06 July 2010 - 06:51 PM
1. Yes always
2. The rail has a stud at each end which passes through the gasket-spacer and into the hole in the roof and roof strengthen plate and then fixed with a washer and nut.
So u can seal externally insitu with ie. Sikaflex or similar, or remove the rail and fit new gaskets.
1997 Discovery ES V8 auto.
Previously for 10 years 1987 Range Rover Vogue Efi auto, and 2 years 1985 TVR 350i manual.
STAY FROSTY & USE LOGIC ON DIFFICULT JOBS - Get someone else to do it.
