Key fob
Mr magoo
Sorry for the partial hijack....
There is a restart sequence? I was about to change the battery in my 1996 two button fob - its getting a bit hit and miss and I've not changed it in the three years I've had it.
I'll have to try to remember which side lock is, I never seem to get it right first time!
Is there anything else I need to be aware of, and incidentally, what battery does the fob take?
Stu.
The
Stu.
The fob battery is a CR2032.
This info is for programming a single button fob, as I have a two button fob i've never had to use it so I don't know if it works.
1. Ensure ignition is OFF, doors unlocked, bonnet switch closed.
2. Ensure procedure from 3 to 9 is completed within 8 seconds.
3. Switch Ignition ON
4. Switch Ignition OFF
5. Lock Doors and Unlock Doors
6. Release Bonnet Switch
7. Switch Ignition ON
8. Switch Ignition OFF
9. If alarm is set, horn will sound and LED with light. Now programming of plips can be completed.
10. Press and hold down button on plip until LED flashes.
11. Repeat for additional plips.
12. The dash LED will extinguish if both plips have been programmed successfully
hello!
I tried to program an defender fob to my new disco ( it came only with 1 working fob). I never get that "point 9 alarm sounding" and Im 101% sure that im doing it right! What might be wron/what Im doing wrong? Disco 1 V8 -98
cheers
Jan
That procedure is for a single button fob only. A 98 Disco should have a 2 button fob.
  • 3 months later...
I recently bought a 200TDI previous owner said the key fob only works sometimes..When I tried it it seemed like the fob batteries were dead ..I replaced them and the fob worked OK for a week..Then the fob batteries went flat..I replaced them again with batteries sourced from a motor factors but It still doesnt work..Ive gone through the procedure and alls fine up till the horn bleeps and the dash light comes on ..I then hold the button down but nothing changes the light in the dash stays on..Plus if I manually lock drivers door the central locking doesnt work either..If I switch ignition on the light goes out on dash C/locking then works fine..Pulling my hair out now ..Anyone any ideas ? Thanks in advance
