td5 broke again Posted March 25, 2017 Share Posted March 25, 2017 Hi all I have brought a 2000 discovery td5 and it's playing up! It was holding back misfiring really bad at times and cutting out as and when it felt like it....so I've changed injector harness due to oil leak plus cleaned plug/ecu...blanked off egr as code reader said it was stuck open and freed off the waste gate as it was seized. ..all of this didn't seem too cure the holding back/misfire 100% but deffo run loads better. ..so I serviced it ....changed diesel filter started it ran for around a minute or so n died. ..now won't run at all...pls any help would be great...I can't hear any noise from the fuel pump at and haven't since getting it not Evan with the ignition on and engine not running...It went sounding great too missing it's chuff off too cutting out Quote Link to comment Share on other sites More sharing options...
td5 broke again Posted March 25, 2017 Author Share Posted March 25, 2017 Plus I filled diesel filter with fuel cleaner...could this be at fault...like I've said it ran for minute or two but I've took drain plug out of filter and it's only gt the fuel cleaner in it and no diesel.... Quote Link to comment Share on other sites More sharing options...
reb78 Posted March 26, 2017 Share Posted March 26, 2017 Sounds like it was originally the injector seals to me and now the diesel system also has air in it following the filter change and needs purging properly. From your original description though, do the injector seals. 1 Quote Link to comment Share on other sites More sharing options...
bear Posted March 26, 2017 Share Posted March 26, 2017 Doesn't sound as if he can hear the fuel pump so this may have died. 1 Quote Link to comment Share on other sites More sharing options...
dave88sw Posted March 27, 2017 Share Posted March 27, 2017 As said the misfire and original cause of the issue was probably the injector seals. When they go they can put a lot of soot into the fuel system which can gum the pump up, i often take them out and they're black all over. If you can't hear the fuel pump, first of all swap the relay in the fusebox for a known good one (i usually swap it with the wiper relay next to it) to rule that out but you'll probably need a replacement. With everything sorted, before starting, turn the ignition on and pump the throttle pedal all the way to the floor and back up 5 times, this will run a fuel priming cycle, the pump will run on and off and the engine management light will flash, leave it until it finishes the cycle (light stops flashing) and then try and start, they often fire better with the throttle pedal fully depressed but lift off quickly when it starts to prevent it revving too high. 1 Quote Link to comment Share on other sites More sharing options...
td5 broke again Posted March 27, 2017 Author Share Posted March 27, 2017 Hi guys sorry for slow reply I've checked the plug on the fuel pump and have got a earth and live so ran a earth n live straight to the pump with the plug off and the pump won't run....so will be ordering a new one... Thanks for ur help and ill be doing injector seals too as the diesel in the tub I used to drain filter is dark / discoloured. .Thanks again ill keep posted on how it goes lol Quote Link to comment Share on other sites More sharing options...
td5 broke again Posted March 30, 2017 Author Share Posted March 30, 2017 (edited) Hiya all I changed pump for brand new one did the prime procedure fired up and runs like a dream? Thanks for all your help very much appreciated ??? Edited March 30, 2017 by td5 broke again Quote Link to comment Share on other sites More sharing options...
