Kierran.M.110 Posted May 11, 2013 Author Share Posted May 11, 2013 cheers, for that Quote Link to comment Share on other sites More sharing options...
western Posted May 11, 2013 Share Posted May 11, 2013 200tdi engine wiring, 4 cylinder diesel wiring & key, I tend to use these 3 more than the '86 to '91 composite wiring diagram hope they help Quote Link to comment Share on other sites More sharing options...
Kierran.M.110 Posted May 13, 2013 Author Share Posted May 13, 2013 from looking at the diagram and then looking at the wiring the only thing i can think of being the problem is a bad or no earth will have to investigate further Quote Link to comment Share on other sites More sharing options...
Kierran.M.110 Posted May 13, 2013 Author Share Posted May 13, 2013 now i have the brake relay ticking when i turn the key, there has to be an immobiliser gitted to it thats the problem Quote Link to comment Share on other sites More sharing options...
nickwilliams Posted May 14, 2013 Share Posted May 14, 2013 The crank relay coil is earthed via a black wire with a green stripe which goes to the terminal on the bulkhead inside the engine bay. This wire is used to inhibit the crank function when not in park on vehicles fitted with an automatic transmission. The engine won't crank unless it is earthed. It took me about four hours to spot this one when I did my re-build.... Nick. Quote Link to comment Share on other sites More sharing options...
Kierran.M.110 Posted May 15, 2013 Author Share Posted May 15, 2013 the black green wire goes to a standard plug in the engine bay and i do not believe that there is any more earth terminals to be connected but i will have another look at the weekend. and how would i have a crank relay coil on automatics if i have a mannual Quote Link to comment Share on other sites More sharing options...
nickwilliams Posted May 17, 2013 Share Posted May 17, 2013 The relay is fitted to both manual and automatics - it carries the starter solenoid current so it does not have to go through the ignition switch. On manual vehicles, the bullet on the end of the black-green wire is permanently connected to a black wire from the main bulkhead earth terminal. On automatics, it is connected to a switch which is only closed when the gearbox is in 'P'. Quote Link to comment Share on other sites More sharing options...
Kierran.M.110 Posted May 17, 2013 Author Share Posted May 17, 2013 so could i try earthing the relay on its own from that wire (i am rubbish at electrics if you havnt guessed already) Quote Link to comment Share on other sites More sharing options...
western Posted May 17, 2013 Share Posted May 17, 2013 as above the black/green wire is earthed to the bulkhead earth point, the white/red wires go to starter soleniod & ignition switch, the plain brown is 12v feed from the battery. Quote Link to comment Share on other sites More sharing options...
Kierran.M.110 Posted May 18, 2013 Author Share Posted May 18, 2013 had a look this morning and i have the ring terminal for the earth wire attached to the bulkhead already so i tried cutting the black/green and earthing it independantly and it worked so i just have to sort out the bad earth and i should be ready to start once i get diesel and get 2 pipes to go to the heater matrix, cheers for your help. Quote Link to comment Share on other sites More sharing options...
western Posted May 18, 2013 Share Posted May 18, 2013 good to read your making good progress. Quote Link to comment Share on other sites More sharing options...
