zardos Posted April 17, 2010 Share Posted April 17, 2010 There is a bit of slack in my 4 bolt steering box. You turn the input shaft a bit and the output shaft does not move. Can this slack be adjusted out and how do you do it? Thanks Quote Link to comment Share on other sites More sharing options...
Les Henson Posted April 17, 2010 Share Posted April 17, 2010 There's a nut on the top of the steering box on a threaded stud. Raise the front wheels off the ground, slacken the nut and turn the inner stud - checking the play in the steering as you go. Once the play has been taken up and the steering moves smoothly from lock to lock - tighten the locknut - making sure the stud doesn't move as you do so.. Les. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted April 17, 2010 Share Posted April 17, 2010 I've never found this to work very well TBH since by the time you've adjusted the play out, you get a tight spot elsewhere in the rotation. By the time you've backed off the tight spot on the adjuster you're back to square 1 with the play. HTH Mo Quote Link to comment Share on other sites More sharing options...
zardos Posted April 17, 2010 Author Share Posted April 17, 2010 There's a nut on the top of the steering box on a threaded stud. Raise the front wheels off the ground, slacken the nut and turn the inner stud - checking the play in the steering as you go. Once the play has been taken up and the steering moves smoothly from lock to lock - tighten the locknut - making sure the stud doesn't move as you do so.. Les. Thanks I'll give it a go. Quote Link to comment Share on other sites More sharing options...
dantd5 Posted April 17, 2010 Share Posted April 17, 2010 As ^^^by Les this is a close view of the nut and pin hole. Quote Link to comment Share on other sites More sharing options...
zardos Posted April 17, 2010 Author Share Posted April 17, 2010 Adjusted up, no tight spots and no play. Thanks Quote Link to comment Share on other sites More sharing options...
carlosbeldia Posted April 19, 2010 Share Posted April 19, 2010 Does this works in my TD5? Quote Link to comment Share on other sites More sharing options...
Les Henson Posted April 19, 2010 Share Posted April 19, 2010 TD5 has the same adjuster on the top. Les. Quote Link to comment Share on other sites More sharing options...
