SvBeek Posted March 9, 2017 Share Posted March 9, 2017 I've recently bought a used mech lock device. I'm thinking about what would be a good place to install it in my defender. Obviously because of the route of the clutch pipe somewhere in or around the bulkhead would be good. Does anyone have pics or a description of where they fitted theirs? Thanks Quote Link to comment Share on other sites More sharing options...
HPLP Posted March 12, 2017 Share Posted March 12, 2017 Mine is fitted directly under the steering column with extension pipework through the bulkhead. H Quote Link to comment Share on other sites More sharing options...
cackshifter Posted March 17, 2017 Share Posted March 17, 2017 Fitted mine on the bulkhead just to the right of the fusebox. The install instructions suggested you remove the large rubber grommet there and fit it through there. It's (from memory) about 30mm to the right of the edge of the fusebox coverand up a bit from the knob. Then you remove the short steel pipe from m/cyl to to the hose, and replace it with piping to & from the mechlock valve. I could you get you pics tomorrow if need be. Quote Link to comment Share on other sites More sharing options...
SvBeek Posted March 21, 2017 Author Share Posted March 21, 2017 Thanks for the suggestions. The bulkhead option shounds good, especially since it would need no modifications to it. Quote Link to comment Share on other sites More sharing options...
