Landy7 Posted April 15, 2017 Share Posted April 15, 2017 I swapped the 2.5TD engine for a disco 200tdi in my 1988 - 110 soft top LHD (not driven for 6 months) but now the fuel gauge isn't working anymore, stays at empty. I searched for a solution on the forum and found out that I need to look for a black/green wire. I can find it at the fuel tank, I also checked it in the dash, but can't find it anywhere in the engine bay I tried to follow it from the tank but I get lost at the tail lights.. Anyone knows where it should be in the engine bay? Or is the sender stuck after 6 months of not driving? Quote Link to comment Share on other sites More sharing options...
western Posted April 15, 2017 Share Posted April 15, 2017 the engine swap shouldn't have affected the fuel gauging wiring,if the loom has not been moved or disconnected, more likely a dead sender unit, the wiring from the sender goes across the rear of the tank, to right rear corner, then through the chassis to the engine bay multiplugs, it should be possible to find the green/black trace wire there & ensure it's connected to the matching main/dash loom socket, maybe find the required wire, disconnect at both ends, carry out a continuity test to prove the wire is OK, if not just run a new wire from the sender to gauge along the top of the chassis rail.if the wiring proves good, replace the sender unit. Quote Link to comment Share on other sites More sharing options...
Cornish Rattler Posted April 15, 2017 Share Posted April 15, 2017 (edited) I had a similar problem and accidentally solved it after months running without the fuel gauge reading, just check the wiring immediately next to the fuel filter there should be a thin black wire with a large eyelet on it should be screwed to the bulkhead but after I removed the filter completely from the bulkhead to do a seperate job and found this wire tucked away in the wiring, screwed it to the bulkhead and hey presto the fuel gauge worked I must have missed it some how when I did the engine swap last year, hope this helps Edited April 15, 2017 by Cornish Rattler Quote Link to comment Share on other sites More sharing options...
Landy7 Posted May 11, 2017 Author Share Posted May 11, 2017 (edited) The black wire is still connected to the bulkhead so that's fine. I cannot find the black/green wire in the engine bay at the multiplugs.. Just to be sure, I will connect a new wire straight from the dash to the sender, if that works then it's the original wire, if it still doesn't work, then I will replace the sender. Edited May 11, 2017 by Koen110 Quote Link to comment Share on other sites More sharing options...
Landy7 Posted May 30, 2017 Author Share Posted May 30, 2017 Found the problem .... We had the idea to disconnect the black/green wire from the sender unit and hold it to the chassis, to see if the fuel gauge would go all the way to full, to verify if the cable is still OK, but when we did that, the fuel gauge did not move, but the Parking brake light lit up So it was clear that there was some weird wiring.. Went into the booth and apparently we switched the connectors for parking brake and fuel gauge, they have almost the same colors and have the same layout FIXED! Quote Link to comment Share on other sites More sharing options...
western Posted May 30, 2017 Share Posted May 30, 2017 park brake wiring is or should be white/yellow trace, sounds like a previous owner has bodged it. Quote Link to comment Share on other sites More sharing options...
