Hazard lights inoperative
Right, from the top.
Carling hazard switch fitted, indicators work, hazards don't. 12v at green when ignition is on, 12v at purple when ignition is switched on or off
When switching hazards on, indicators stop working.
Removed the green and the light green wires from the switch, indicators don't work at all. Removing any or all of the other wires has no effect at all on the indiocators
Connected green to light green through a fuse and not via the switch. Indicators work and hazards work, but hazards only work when the ignition is switched on.
Connected light green pin to the fuse holder where the green and light green are connected, hazards work with the ignition off, but the oil pressure, hand brake warning and charging light come on as well
Any thoughts chaps, please? MoT on Tuesday and this is the first time I have tried using the hazards since the test last year
Edited by neil110
additional info
