ajh Posted August 24, 2017 Share Posted August 24, 2017 I'm wondering if anyone has specialised knowledge about steering arm spline patterns/sized etc? I have not been able to find much by searching, at least when it comes to Rovers. For most other 'trucks' a variety of drop arms are available to compensate for lifts and to correct the panhard to steering rod geometry issue that ensues. Specifically, does anyone know if the shaft/spline is a standard of some sort that would make it easy to just grab a modified arm intended for another vehicle for increased drop? If not, any other suggestions? If it matters in this case it is a D2 steering box. Quote Link to comment Share on other sites More sharing options...
missingsid Posted August 24, 2017 Share Posted August 24, 2017 I would also like this information but with relation to Rover cars vs LR products? Quote Link to comment Share on other sites More sharing options...
western Posted August 24, 2017 Share Posted August 24, 2017 I know the 6 bolt & 4 bolt box drop arms are different, any 4 bolt drop arm can be swapped to another 4 bolt box. no idea on spline count/diameter of the shaft. Quote Link to comment Share on other sites More sharing options...
ajh Posted August 27, 2017 Author Share Posted August 27, 2017 On 24/08/2017 at 3:40 PM, western said: I know the 6 bolt & 4 bolt box drop arms are different, any 4 bolt drop arm can be swapped to another 4 bolt box. no idea on spline count/diameter of the shaft. Actually, not all 4 bolt are the same. The pattern seems to be the same but the D2 box output shaft is significantly larger than the earlier ones. Quote Link to comment Share on other sites More sharing options...
western Posted August 27, 2017 Share Posted August 27, 2017 I'll caveat my earlier post by saying applies to 90/110/Defender vehicles. Don't know if any others are common or not. Quote Link to comment Share on other sites More sharing options...
ajh Posted September 19, 2017 Author Share Posted September 19, 2017 Sigh, going to look into doing a new one from scratch I guess... but since the Tomcat is going to be stock height suspension I won't need to do the D2 one for now.. It sure solves a lot of issues. Quote Link to comment Share on other sites More sharing options...
missingsid Posted September 19, 2017 Share Posted September 19, 2017 Very intereseted in where I could get a new one made up? Quote Link to comment Share on other sites More sharing options...
