Wharf33 Posted October 18, 2017 Share Posted October 18, 2017 Have a rather delightful Friday afternoon made Defender 90, 10years old now........developed a moaning noise during speeds of 40mph, LR replaced rear and front diff , transfer box, rear bearings and steering column ( all on Warrenty) in the last year . Sadly this noise is still here ..... slight rubbing to steering area also .... would love to find the answer to tell the LR garage Warwick Quote Link to comment Share on other sites More sharing options...
Tanuki Posted October 18, 2017 Share Posted October 18, 2017 (edited) OK, so it's a Defender - but is it a 200/300TDi, a TD5, or a Puma [and if a Puma is it a 2.2 or 2.4?] Or is it a petrol-engined non-Eurozone offering? Does the moaning come-on or go-away under braking? gentle, or hard acceleration? What speeds in the gears is it noticeable at? If TD5 or Puma, you've of course had the ECU error-codes read before you started randomly replacing parts. If so what were they? Edited October 18, 2017 by Tanuki Quote Link to comment Share on other sites More sharing options...
Lightning Posted October 18, 2017 Share Posted October 18, 2017 Ten years old and still under warranty? I assume it's a TD5. Mine had a similar noise, and it was the exhaust! A new (genuine LR) system cured the mooing noise. I didn't replace the CAT as LR wanted £900 for one lol. I bought the centre box online (new take off) for £80 and the rear section was £185 from LR. Quote Link to comment Share on other sites More sharing options...
Scotts90 Posted October 18, 2017 Share Posted October 18, 2017 Is the wife in the car? on a more helpful note, my exhaust has a certain resonance at engine/road speeds so may be that as Lightning says. Quote Link to comment Share on other sites More sharing options...
HampshireHog Posted October 18, 2017 Share Posted October 18, 2017 Ive just had the head off of my old 200tdi , strangely only heard a moaning sound after the job was done ,when the current Mrs found the invoices for the parts 2 Quote Link to comment Share on other sites More sharing options...
Wharf33 Posted October 19, 2017 Author Share Posted October 19, 2017 On 10/18/2017 at 7:39 PM, Tanuki said: OK, so it's a Defender - but is it a 200/300TDi, a TD5, or a Puma [and if a Puma is it a 2.2 or 2.4?] Or is it a petrol-engined non-Eurozone offering? Does the moaning come-on or go-away under braking? gentle, or hard acceleration? What speeds in the gears is it noticeable at? If TD5 or Puma, you've of course had the ECU error-codes read before you started randomly replacing parts. If so what were they? Hi, The defender is a Hardtop 90 County HT SWB, 57 plate DIESEL 2402cc The noise is more noticable in 4 th gear, and uphill incline. Has become noticible in 5th gear also when cruising at 60mph Paid the addition warenty as had several issues in the last 2 years, but love the troublesome one Quote Link to comment Share on other sites More sharing options...
Wharf33 Posted October 19, 2017 Author Share Posted October 19, 2017 On 10/18/2017 at 8:41 PM, Lightning said: Ten years old and still under warranty? I assume it's a TD5. Mine had a similar noise, and it was the exhaust! A new (genuine LR) system cured the mooing noise. I didn't replace the CAT as LR wanted £900 for one lol. I bought the centre box online (new take off) for £80 and the rear section was £185 from LR. 10 YEARS in January, paid the additional warrenty as it lives at LR allot , well the garage. Intersesting ref exhaust , will check that possability tomorrow Thank you Quote Link to comment Share on other sites More sharing options...
