14Platoon Posted October 29, 2017 Share Posted October 29, 2017 Thought I'd post a photo of my ex MOD Defender currently taking the head off as it's a bit (a lot) smoky at idle. Changing the injectors stem seals and glow plugs, hopefully that'll sort it. It's fine when normal driving, plumes of grey smoke when sat at idle for a time though. 2 Quote Link to comment Share on other sites More sharing options...
PaulN Posted October 29, 2017 Share Posted October 29, 2017 That's really nice! - Something about a Military one! Welcome by the way and I expect some experts will be along shortly. btw - Can I have yer doors and windows!! Quote Link to comment Share on other sites More sharing options...
14Platoon Posted October 29, 2017 Author Share Posted October 29, 2017 Ive had a few jobs completed since my short ownership. Power steering fitted (as optional in some MOD defenders), footwells re plated rather than the crude military plates. Got to sort out the smokey idle and then fit a new power steering pump. Quote Link to comment Share on other sites More sharing options...
14Platoon Posted October 29, 2017 Author Share Posted October 29, 2017 7 minutes ago, PaulN said: That's really nice! - Something about a Military one! Welcome by the way and I expect some experts will be along shortly. btw - Can I have yer doors and windows!! Thanks for the welcome Quote Link to comment Share on other sites More sharing options...
14Platoon Posted October 30, 2017 Author Share Posted October 30, 2017 Heads off......no valve stem seals present! Very stiff valve and one valve with a big pit which is nearly a hole. Quote Link to comment Share on other sites More sharing options...
western Posted October 30, 2017 Share Posted October 30, 2017 that hole is standard finish, https://www.turnerengineering.co.uk/etc-5739-valve-inlet-c2x20634521 & https://www.turnerengineering.co.uk/err-1230-valve-exhaust-c2x20634979 see page 91 2.5 n/a cylinder head parts, items 16 & 17 valve stem seals they are ERR1510 http://www.brit-car.co.uk/product.php/84677/1076/valve_stem_oil_seal_inlet_2_25_2_5 & ETC4751 http://www.brit-car.co.uk/product.php/85632/0/valve_stem_oil_seal_exhaust_2_25_2_5_diesel_ listed, http://www.retroanaconda.com/landrover/parts_books/110/2_engine_25P_25D_25TD_p17-167.pdf just replaced all the valves in my 200tdi, they all have that hole, Quote Link to comment Share on other sites More sharing options...
14Platoon Posted October 30, 2017 Author Share Posted October 30, 2017 Now I'm confused? How come one of my valves had that hole then? Was it just a different replacement that someone used? Also are he inlet and exhaust valve stems seals different? They look the same. Thanks Quote Link to comment Share on other sites More sharing options...
14Platoon Posted October 30, 2017 Author Share Posted October 30, 2017 Thanks Western......just reorganised the valve stem seals, wouldn't have realised there was a difference otherwise! Quote Link to comment Share on other sites More sharing options...
western Posted October 30, 2017 Share Posted October 30, 2017 might be a spare valve that the base workshops had in stock, or the others are full of carbon deposit from the combustion process. Quote Link to comment Share on other sites More sharing options...
14Platoon Posted October 30, 2017 Author Share Posted October 30, 2017 5 minutes ago, western said: might be a spare valve that the base workshops had in stock, or the others are full of carbon deposit from the combustion process. Thanks mate Quote Link to comment Share on other sites More sharing options...
14Platoon Posted November 2, 2017 Author Share Posted November 2, 2017 So as well as no valve stem seals present whatsoever, I've realised a bolt is missing from the rocker arm set up........I haven't got one but don't really want to put it back missing one as it was. Quote Link to comment Share on other sites More sharing options...
western Posted November 2, 2017 Share Posted November 2, 2017 rocker cover fixings fit in 2 or 3 of the rocket shaft posts Quote Link to comment Share on other sites More sharing options...
western Posted November 2, 2017 Share Posted November 2, 2017 you need this too http://www.retroanaconda.com/landrover/2009/12/land-rover-defender-90-parts-book/ Quote Link to comment Share on other sites More sharing options...
14Platoon Posted November 2, 2017 Author Share Posted November 2, 2017 48 minutes ago, western said: rocker cover fixings fit in 2 or 3 of the rocket shaft posts Ah so I have two in so assuming that's ok then? ps I saved the parts book.......many thanks. Quote Link to comment Share on other sites More sharing options...
western Posted November 2, 2017 Share Posted November 2, 2017 have a look at the rocker shaft page in the relevant engine section, IIRC the rocker cover has 3 studs in the top of cylinder head/rocker shaft as well as the 2 bolts Quote Link to comment Share on other sites More sharing options...
14Platoon Posted November 2, 2017 Author Share Posted November 2, 2017 12 minutes ago, western said: have a look at the rocker shaft page in the relevant engine section, IIRC the rocker cover has 3 studs in the top of cylinder head/rocker shaft as well as the 2 bolts Yes I have three bolts to go through the rocker cover and into the rocker arm set up. Still looks to be one bolt missing. Quote Link to comment Share on other sites More sharing options...
14Platoon Posted November 2, 2017 Author Share Posted November 2, 2017 14 minutes ago, western said: have a look at the rocker shaft page in the relevant engine section, IIRC the rocker cover has 3 studs in the top of cylinder head/rocker shaft as well as the 2 bolts This shows the set up with the three bolts waiting to go through the cover into the rocker arm set up. This would still leave one bolt missing. I have put the bolt heads onto the bolts for illustration purposes. You can see the bolt hole that will be left redundant at the rear of the photo. To clarify the 4th bridge from the front (2nd from rear) is missing a bolt Quote Link to comment Share on other sites More sharing options...
western Posted November 2, 2017 Share Posted November 2, 2017 if there is no remains of a bolt in that hole, [could of sheared off & no-one has bothered to replace it] just get a new bolt & fit, provided the threads in the head are intact. Quote Link to comment Share on other sites More sharing options...
14Platoon Posted November 3, 2017 Author Share Posted November 3, 2017 6 hours ago, western said: if there is no remains of a bolt in that hole, [could of sheared off & no-one has bothered to replace it] just get a new bolt & fit, provided the threads in the head are intact. Yeah I'm guessing they forgot it (or didn't bother) as well as the valve stem seals. Quote Link to comment Share on other sites More sharing options...
14Platoon Posted November 9, 2017 Author Share Posted November 9, 2017 So I completed a recon of the head and parts, no plumes of smoke. At idle for over an hour, if I blast the throttle I get a bit of smoke (grey) but not wispy or plume. Is this normal? I have a video but can't seem to upload it? Quote Link to comment Share on other sites More sharing options...
western Posted November 11, 2017 Share Posted November 11, 2017 I'm not overly familiar with the 2.5 n/a diesel, but a bit of smoke when revved from idle shouldn't be to much to worry about, see how it goes once it's all back together & in normal driving use. Quote Link to comment Share on other sites More sharing options...
14Platoon Posted November 11, 2017 Author Share Posted November 11, 2017 On 02/11/2017 at 9:23 PM, western said: rocker cover fixings fit in 2 or 3 of the rocket shaft posts Very pleased, no smoke after a very long idle. Just passed MOT with no advisories, flew through the emissions test. Quote Link to comment Share on other sites More sharing options...
