giacomo.m Posted November 8, 2017 Share Posted November 8, 2017 Hi all, 2007 Puma 2.4 Tdci with abs and tc light illuminating in the dash, when I try to do the diagnosis, wabco abs ecu not communicating with Hawkeye Pro and at a certain point the message appears: you want to check the A-B-C......wiring harness but after losing communication can someone help me ? thank you Quote Link to comment Share on other sites More sharing options...
Arjan Posted November 8, 2017 Share Posted November 8, 2017 Have you charged the battery fully ? Low(ish) voltage can cause comms problems.. Quote Link to comment Share on other sites More sharing options...
Ally V8 Posted November 8, 2017 Share Posted November 8, 2017 As Arjan says, low battery voltage may be the issue,as can blown fuses and loose earth connections - It may be just that the ecu is not awake. Also Wabco ABS ecu's will refuse to connect if they have been awake for too long. Switch off,let it power down for a minute, then try again. Quote Link to comment Share on other sites More sharing options...
giacomo.m Posted November 8, 2017 Author Share Posted November 8, 2017 5 hours ago, Ally V8 said: As Arjan says, low battery voltage may be the issue,as can blown fuses and loose earth connections - It may be just that the ecu is not awake. Also Wabco ABS ecu's will refuse to connect if they have been awake for too long. Switch off,let it power down for a minute, then try again. Thank you Ally V8 battery 100% ok but I do not understand when you say the ecu is " not awake " what does that mean ? Giacomo Quote Link to comment Share on other sites More sharing options...
Ally V8 Posted November 8, 2017 Share Posted November 8, 2017 What I mean is that if a supply fuse is blown,a supply or earth wire is broken or connector loose - the ecu will not be powered up,or "awake" Can you communicate with the engine or alarm ecu properly ? If you can its likely the ABS ecu is not awake. Quote Link to comment Share on other sites More sharing options...
giacomo.m Posted November 9, 2017 Author Share Posted November 9, 2017 I understand but I did the diagnosis on the ecu engine and it's all ok Giacomo Quote Link to comment Share on other sites More sharing options...
Ally V8 Posted November 9, 2017 Share Posted November 9, 2017 (edited) Ok, thats good, it means the diagnostic socket is powered and working. You need to get a wiring diagram and check the fuses, feeds and earths to the ABS ecu next. Edited November 9, 2017 by Ally V8 Bad keyboard skills and cold fingers... Quote Link to comment Share on other sites More sharing options...
giacomo.m Posted November 9, 2017 Author Share Posted November 9, 2017 Thank you Ally V8 do you know where I can find this wiring diagram on the web ? Giacomo Quote Link to comment Share on other sites More sharing options...
Mudmonkey Posted November 9, 2017 Share Posted November 9, 2017 https://onedrive.live.com/?id=4BC2D89C85C7C171!551&cid=4BC2D89C85C7C171 Plus other useful documents for Pumas Quote Link to comment Share on other sites More sharing options...
giacomo.m Posted November 9, 2017 Author Share Posted November 9, 2017 Thank you Mudmonkey, I hope the RHD manual also goes well for LHD Giacomo Quote Link to comment Share on other sites More sharing options...
