moose Posted December 11, 2006 Share Posted December 11, 2006 morning all, I replaced the cam belt about a month ago and done about 1000 miles, I was just changing the case cover at the week end and found it had a fair amount of oil in it i didnt replace the crank oil seal when i did the belt, and this can only have happened in the last week or so as i would have seen the oil when taking out the wading plug so iam now, putting in a new crank seal ( any tips on getting the old one out? ), but do i need to replace the belt, as i remember some where that getting them covered in oil is bad for them.. Quote Link to comment Share on other sites More sharing options...
nige90 Posted December 11, 2006 Share Posted December 11, 2006 I would, oil isn't good for them and after all, they're not expensive. Nige Quote Link to comment Share on other sites More sharing options...
BogMonster Posted December 11, 2006 Share Posted December 11, 2006 You have to take the belt off anyway to change the seal, so as the work is more hassle than the cost, change it again now Do the camshaft seal at the same time for the same reason! Quote Link to comment Share on other sites More sharing options...
Les Henson Posted December 12, 2006 Share Posted December 12, 2006 Oil contamination weakens the belt, I would recommend you replace it. Les. Quote Link to comment Share on other sites More sharing options...
