Sensor for the Brantz International 2 Pro rally trip meter
Arjan
Goede Avond,
I use the " Brantz International 2 Pro rally trip meter" ind was wondering what others with these meters use for the signaal input.
I used to have magnets on the hand brake drum - but with the new set up, that's not an option.
There is no drum..
Suggestions please !
I’ve got the basic Terratrip model, which I had on my Series, and which took s signal from the Speedo cable. (I cut it in half and clipped the sensor between the two halves.) Then I transferred the Terratrip to my 90, and cutting the speedo cable wasn’t an option for me, so I attached a piece of flat steel about the size of my little finger to the prop shaft bolts. You can get a proximity sensor which takes a signal every time the prop shaft rotates. Assume there must be something similar for the Brantz.
