Marc.be Posted March 10, 2018 Share Posted March 10, 2018 Hello, I just started my 200tdi range rover after a little bit more than a year. My oil pressure light stays on, I never had an oil pressure problem before with this engine. Is it possible i have to bleed the oil pump on a 200tdi? Kind regards, Marc Quote Link to comment Share on other sites More sharing options...
western Posted March 10, 2018 Share Posted March 10, 2018 Doesn't need bleeding it picks up direct from the sump. could be a stuck pressure relief valve which means oil drain & sump off to access the relief valve as its within the oil pump casing, or it could be a failed warning light sender unit or it's wire may have become corroded & briken from its terminal or some wildlife has chewed through the wire. Quote Link to comment Share on other sites More sharing options...
walace58 Posted March 10, 2018 Share Posted March 10, 2018 The only time I had this (and of course we panic don’t we!) it just needed a new oil switch. If it on all the time I do not think it would be a disconnected wire, as I didn’t think it would come on at all. 1 Quote Link to comment Share on other sites More sharing options...
Marc.be Posted March 11, 2018 Author Share Posted March 11, 2018 Hi, Thanks for the replies ! I'll start with a new switch. Marc Quote Link to comment Share on other sites More sharing options...
western Posted March 11, 2018 Share Posted March 11, 2018 delete please. Quote Link to comment Share on other sites More sharing options...
