HampshireHog Posted August 9, 2020 Share Posted August 9, 2020 Finally got around to fitting the new blower control unit , nicely designed bit of kit and an easy fit ...... however I discovered that one of the goons who previously owned my old 90 has had their greasy mits in more of the wiring loom , this time at the heater box end , see attached pic , can’t begin to work out why the merry hell he, she or it cut the multi plug off and tried to splice in extra bits of wire to replace it . I’m after a bit of clarification on the green /white (green/slate) connection to the new controller box , is this the from the motor , any help / info greatly appreciated. Side note to Arjan , English only please 😉 Quote Link to comment Share on other sites More sharing options...
western Posted August 9, 2020 Author Share Posted August 9, 2020 I'll go & take some photo's & notes from my 110. back soon On the new control box, with the wire terminals facing you. From left to right. From heater motor 2 way connector & the purple/green from the 3 way connector to the terminal marked Purple Create a new earth lead to a easy to access bolt & fit to terminal marked Black The green/white that comes out of the heater resistor, this is not required so terminate it safety with a inline crimp or female bullet connector The Green/white from the blower motor earth wire to terminal marked Green The next 3 wires are from the cab via the new wiring that came with the switch kit. Quote Link to comment Share on other sites More sharing options...
western Posted August 9, 2020 Author Share Posted August 9, 2020 I'm guessing you have the Land reiziger fitting info. Quote Link to comment Share on other sites More sharing options...
HampshireHog Posted August 9, 2020 Share Posted August 9, 2020 Western if I weren’t for social distancing and the fact Cornwall weren’t so far from Aldershot , I’d give you a kiss . I had kind of sorted it in my head but just needed a bit of clarification on the green/white wire , yes I followed the instructions supplied but it was the rats nest I uncovered ,and still need to sort, that threw me , thank you once again .👍 Quote Link to comment Share on other sites More sharing options...
western Posted August 9, 2020 Author Share Posted August 9, 2020 Pleased it helped, hopefully you'll have it working soon. Quote Link to comment Share on other sites More sharing options...
