defender dinky Posted May 12, 2018 Share Posted May 12, 2018 Hi, defender 110 1990 project nearly finished, got some issues with clutch it's a discovery gearbox n engine in defender, bled clutch traditional way two people no joy then used easy bleed no joy have fluid coming out of nipple plentiful but can't get gears when engine running can get gears when engine off any ideas should I invest in new m/s cylinders, dd Quote Link to comment Share on other sites More sharing options...
ballcock Posted May 12, 2018 Share Posted May 12, 2018 Can you feel the clutch plate spring pressure through the pedal? Has the clutch just been replaced or if it was attached to the fly wheel when you installed the engine? Have you tried to start the engine with it in gear and the clutch depressed? ( make sure the hand brake is on and working chock wheels etc,) If the plate is seized this might release it. Quote Link to comment Share on other sites More sharing options...
supaimpy Posted May 12, 2018 Share Posted May 12, 2018 Does the piston actually retract? had this when I finished my chassis swap , the clutch bled perfectly but first application piston moved and stayed there , slacken the two bolts, if the cylinder moves back as you release them then you have your answer , clutch is stuck in disengeaged position. Quote Link to comment Share on other sites More sharing options...
V8 Freak Posted May 12, 2018 Share Posted May 12, 2018 Clutch slave bleed nipple is at the top ? Quote Link to comment Share on other sites More sharing options...
defender dinky Posted May 13, 2018 Author Share Posted May 13, 2018 Yes bleed nipple at top, will try other option as above, dd Quote Link to comment Share on other sites More sharing options...
defender dinky Posted May 13, 2018 Author Share Posted May 13, 2018 Tried ball cock idea foot depressed while in 1st start engine lift off slowly engine noise differ but can't get out of gear while engine running, dd Quote Link to comment Share on other sites More sharing options...
defender dinky Posted May 13, 2018 Author Share Posted May 13, 2018 Can get out of gear now with engine running also lift foot off completely while in gear engine running but no movement?, dd Quote Link to comment Share on other sites More sharing options...
supaimpy Posted May 13, 2018 Share Posted May 13, 2018 the piston is stuck forward on slave Quote Link to comment Share on other sites More sharing options...
defender dinky Posted May 14, 2018 Author Share Posted May 14, 2018 Taking slave off today update later, dd Quote Link to comment Share on other sites More sharing options...
supaimpy Posted May 19, 2018 Share Posted May 19, 2018 any answer on this ? Quote Link to comment Share on other sites More sharing options...
