Keeper96 Posted June 21, 2018 Share Posted June 21, 2018 Hi guys I’ve got my 90 off the road for some repairs to get it through an mot buts going to be off for about a year so I’m planning on doing some bigger jobs while I’m on. The engine is good but it’s just got a general air of old age so I’m planning on giving it some tlc without going to a full rebuild, I’m thinking new big end shells, piston ring and a head gasket plus the usual seals etc. Can anyone recommend good suppliers of bearings or should I just go for genuine items seeing as they’re known to last? Jamie Quote Link to comment Share on other sites More sharing options...
western Posted June 21, 2018 Share Posted June 21, 2018 get your internal parts from Turner Engineering https://www.turnerengineering.co.uk/land-rover-300-tdi-engine-parts-c102x3005632 bought all the bits for my 200Tdi rebuild from them, no problems at all, even sent me a new set of rings for one piston as I found one ring broken on opening/unwrapping the pistons. Quote Link to comment Share on other sites More sharing options...
rick Posted June 24, 2018 Share Posted June 24, 2018 Can second Turners. I'm on the other side of the world and I bought the head, injectors, pistons/rings from Tuners when I o/hauled my old 300Tdi. Quote Link to comment Share on other sites More sharing options...
Keeper96 Posted June 25, 2018 Author Share Posted June 25, 2018 Thanks guys, I totally forgot turners even existed! Is there anything else you would be doing once it’s on bits or just wait and see depending on what I find? Jamie Quote Link to comment Share on other sites More sharing options...
western Posted June 25, 2018 Share Posted June 25, 2018 I went right through mine, replaced anything I wasn't happy with, head got skimmed, new valves,seats recut, guides were measured didn't need changing. block got rebored, new main big, small & main bearing, camshaft & bearings, all followers, rockers & shaft,new piston oil spray banjo bolts [as these have a relief valve inside], oil pump internals & relief valve/spring, oversize pistons to suit rebore, new timing belt & tensioners, injectors refurbished. Quote Link to comment Share on other sites More sharing options...
Snagger Posted June 25, 2018 Share Posted June 25, 2018 Check the valves and guides, the cam followers (they often end up like 50p bits), consider replacing the oil pump relief valve if not the whole pump, and of course the timing belt and tensioner. I'd have the injectors cleaned, too. Quote Link to comment Share on other sites More sharing options...
mmgemini Posted June 25, 2018 Share Posted June 25, 2018 Check that the nose of the crankshaft is in good order and square where the oil pump fits Quote Link to comment Share on other sites More sharing options...
