blz6662 Posted August 23, 2018 Share Posted August 23, 2018 Hi All, To start, sorry if this is a dull question. I have a Disco 1 1997 V8 donor vehicle with an extremely good steering box (straight arm STC2846) which I want to fit to my Range Rover Classic 1987 V8 EA Chassis. This vehicle has the bent drop arm NTC1580 steering box fitted. I need to do a quick swop without getting into 'drop arm wars' so the intention was to remove each box with drop arm and steering bar removed at the passenger side (Disco has 4 ball joints total/Range Rover 3 ball joints). Then refit onto opposite vehicles as I need to move the donor Disco around the yard. So, will these boxes exchange ok with their relative rods? Also are the splines the same on these boxes as I will fit the correct drop arm and steering rod at a later date. The Range Rover is not used on the road at the moment just estate duties. Thanks in advance blz6662 Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted August 23, 2018 Share Posted August 23, 2018 Yes, yes. Quote Link to comment Share on other sites More sharing options...
blz6662 Posted August 23, 2018 Author Share Posted August 23, 2018 Thanks Bowie69, good news - best get on with it then! Quote Link to comment Share on other sites More sharing options...
Blanco Posted August 24, 2018 Share Posted August 24, 2018 It is great when there is a nice 'straightforward' answer Quote Link to comment Share on other sites More sharing options...
